Question about Sony Playstation 3 (PS3) Console
PS3 USB Ports
I need to replace 3 of the 4 USB ports on my PS3. I can do it myself if anyonw knows how to open up the PS3
  • norstarzz Jan 05, 2009
    My usb ports are not working wont charge controllers or use buzzer. Where can i get the 4 front USB ports to replace? Yes my PS3 is 2 years old. Please help/
  • 182 Answers
How old is your ps3? if less than a year dont open or it will cancel your warranty.
Posted on Jan 07, 2008
Ps3 stopped reconizeing usb ports
Most common issue (assuming it hasn't been modded) is simply dirty connections. With the power off and unplugged (say saying to protect myself so someone doesn't get electrocuted), use compressed air to spray out thee ports. From there, dip q-tips in isopropyl (rubbing) alcohol and gently clean the metal connections on both the PS3 and device that is being connected. There is a chance that one of the tiny metal connectors have broken off. If the other port is still working, you could pick up a hub which is a device that has one USB end that plugs into the PS3 but multiple input ports to allow multiple devices.
Sep 17, 2013 | Sony Playstation 3 (PS3) Console
How to play play ps2 games on your ps3
You can only play PS2 games on your PS3 if it is backwords compatible, and the easy way to find out is to see how many USB Ports are in front of the console. If you have 2 USB Ports, no go. If you have 4 USB Ports in front, it is backwords compatiable. Another easy way to find out is if you own a fat PS3 with 4USB Ports you are good to go, just pop the CD in and it will play. If you own a slim PS3, you are out of luck, when Sony intoduced the slim ps3, to save money, they removed the backwords compatible chip from the hardware inside.
Aug 20, 2011 | Sony PlayStation 3 (120 GB) Black Console
Hi i would like to change the NAT settings for my PS3 i have a st585v6 router how can i do this. the ps3 is not wireless
To change the NAT settings you need to open ports on the router. For that
1)Get the TCP/UDP ports from PS3 vendor
2)Get the IP add of your PS3
3)Log into the router interface and open ports for it.
Hope this helped.
Jan 21, 2011 | Computers & Internet
The NAT is on 3 and it needs to be 2 for the PS3 to work online properly. i have a Zyxel_41C.
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Make sure that UPnP is Enabled
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
UDP 3659
UDP 3660
You can use to test if the ports are open.
Jan 14, 2011 | Zyxel P660HW-D1 Router
I need help changing my nat settings from strict to open for my ps3, i have a bt home hub router, and my upnp is enabled, is there anything else i can do???
You will have to open the following ports in your BT router
Make sure the firewall is disabled in the Router
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
UDP 3659
UDP 3660
Jan 02, 2011 | Sony PlayStation 3 Slim
My PS3 won't reconize any of my controllers, putting the cable in works, it find the controller, but when I unplug te cable the lights start blinking again and I can't use the controller, what to do?
Hmmm. It sounds like either your PS3's Bluetooth controller is on the fritz, or all of your controllers are on the fritz. Since I doubt ALL of your controllers are malfunctioning, I am betting it's your PS3. I suggest having a friend with a working controller stop by and test his controller against your PS3. IF your friend's controller works, then you know that the PS3's Bluetooth controller is working.
Second step is to check to see if the USB cable is transmitting a trickle charge to the controller. Again, using your friend's controller (make sure he brings his own USB cable with him), try charging his controller with HIS cable first. If after 10 minutes of playing with the controller plugged into the PS3 via USB, you unplug it and the controller still works, then the problem is most likely your own USB cable (it's apparently damaged in some way). Now run down the controller's battery and try recharging it with YOUR USB cable. If it fails to charge, then you know that all you need is a new cable. Just in case, make sure you test EACH of your USB ports. A simple replacement will cost you around $10.
Otherwise, your PS3's UBS port(s) are not properly working and you should send in your PS3 for repairs. As stated above, test each of the USB ports on your PS3. My 60GB one has 4 USB ports, so I would test all 4 of them before sending in the PS3. Then, if you want it repaired, make notes of which port(s) is(are) malfunctioning and send it to an authorized PS3 repair center.
Dec 24, 2010 | Sony BD Remote Control for Playstation 3
Hello i need to open some ports in order for my ps3 will function properly..I need the Tcp ports open #'s (80)(443)(5223)(10070)(10080) and also need the UDP ports open #'s (3478)(3479)(3658)(10070) model...
Step 1 : Connect Router - Computer
Step 2 : Open Router Setup by typing http ://
Step 3 : Click Applications and Gaming
Step 4 : Click DMZ
Step 5 : Select Enable and Give the IP Address of the XBOX/PS3/Wii in it
Step 6 : Click Save settings
Step 7 : Unplug the Power cord from the router and turn Off XBOX /PS3/Wii
Step 8 : Plug the power cord back to the router and wait till the lights are Solid
Step 9 : Turn on the Xbox/PS3/Wii
Step 10 : Test the Connection
Else ...
Under application and gaming you can find port range forward
There you can open the ports one by one
And give the IP Address of the PS3 for all the ports opened
Dec 21, 2010 | Linksys Wireless-G WRT54G Router
PlayStation 3 keep getting nat type 3 when need type 2
I was having problems with my PS3 as well I did the following
updated firmwire
Also I assign static ip address on my PS3 and forward ports used by PS3 to static IP address of PS3 on routers firewall.
Ports used by PS3:
udp 3478
udp 3479
udp 3658
tcp.domain (port 53)
udp.domain (port 53)
tcp.http (port 80)
tcp.https (port 443)
udp.ssdp (port 1900)
tcp.amandaBackupInitiation (10080)
tcp.Jabber SSL/TLS (port 5223)
If your still getting problems configure the PS3 to be in your DMZ.
DMZ will be under applications and gaming. Just look for that setting in your routers setup page and add your PS3 IP address to it.
Mar 15, 2010 | Linksys WRT160N Wireless Router
Ps3 usb ports not working
I think your ribbon for the ports might of came unplugged check it out!
Feb 01, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
210 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
