RICOH AFICIO 2027 SC392 CODE,IM AN ENGINEER AND RESET SC CODES BUT STILL DOESNT WORK. HAVENT COME ACROSS THIS BEFORE.I KNOW ITS TD SENSOR FAULT, CHANGED WITH ANOTHER 2ND HAND UNIT I KNOW WAS WORKING FINE BUT DRUM WAS WORN ON EDGES, STILL SAME FAULT? THEIR ARE NO SEAL BEEN LEFT IN UNITS. PLEASE HELP.
• Someone forgot to remove the toner seal of the PCU • ID sensor defective • TD sensor abnormal • Drum does not turn • Development roller does not turn • Poor connection of the PCU drum unit Clean connector of TD sensor and Try Change the development unit, adjust TD sensor. Clean and you verify
the connector of PCU. Good luck...
Was this helpful?
Yes
No
Popular Solutions for Ricoh Aficio 2022 All-In-One
We have ours on the network, and it is set up to forward all incoming faxes to an email address...
(More)
We have ours on the network, and it is set up to forward all incoming faxes to an email address instead of printing. It was working fine, then it started printing faxes, and on the Communication Failure Report, it is saying the error is #1 Hang up or line fail. The email account is good and is reciving emails just fine. How can we fix this.
I Cannot install Ricoh 2022 with snow leopard. I tried to use the drivers I found in...
(More)
I Cannot install Ricoh 2022 with snow leopard. I tried to use the drivers I found in www.ricoh-support.com but they are for leopard (10.5) and they don't work. I also used the drivers I found from apple (ricoh 2022 gutenprint v.5.2.3) but nothing again. The printer seems to be installed but when I try to print something it doesn't go to the printer (usually it stops at 59% in the quew). The IP adress is right and checked and the printer is on. Do you have any idea? Thanks
Everything I print from my Brother HL-5240 printer comes out with both sides of the paper/check...
(More)
Everything I print from my Brother HL-5240 printer comes out with both sides of the paper/check curled up.
