Question about Canon PIXMA iP1600 Printer
Canon iP1600 Will not run. Keep getting service error 6000
    President:
  • 1,944 Answers
Try disconnecting the printer from everything (power/PC) for an hour then reconnect and power on.
Posted on Dec 26, 2007
  • Damen Wong
    Damen Wong Dec 26, 2007
    Also, try this troubleshooting guide from Canon.
  • Damen Wong
    Open the printer and examine the insides to see if there is anything foreign inside (including dust and paper). Check that the paper tray is in it's proper position to feed the printer. Check the printer rollers that pull the paper into the machine.
  • 790 Answers
According to the error its an paper jam ... But i guess everything is fine right ??
  • Kanth raj
    Kanth raj Dec 26, 2007
    May be the small paper pieces hav jammed inside if not do this
    switch off the printer and disconect the USB cable for 30 seconds. deep clean on the black head to get it work
    properly.
  • Kanth raj
    My friend had the same issue and he fixed it by this tip !! Hope it works to u too ...
    GUD LUCK!!
Service error 6000 for canon pixma iP 1600
Error 6000
An error occurred in the LF encoder signal.
Can be the result of a deep paper jam with pins, paper or other miscellaneous objects stuck in there.
Check the unit and clean thoroughly.
Jan 15, 2013 | Canon PIXMA iP1600 Printer
Error 6000 in canon mx328
Hello thanks for using fixya
Error 6000 is a service call error, meaning that the printer needs to be taken to a authorized service facility for repair. Its actually a line feed error, with the problem originating from the timing disk film or the printer's logic board.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using fixya
Jan 19, 2011 | Canon Office Equipment & Supplies
I have a check printer 6000 error message
Error 6000 is a service call error, meaning that the printer needs to be taken into a canon authorized service facility for repair. Its actually a line feed error, with the problem originating from the timing disk film or the printer's logic board.
Please keep thumbs up in do Rating if it is helpful
Dec 30, 2010 | Canon PIXMA MX310 All-In-One Printer
I get an error 6000 message
halo printer ku canon ip 1980 gmn cara resetnya,...
Jan 11, 2010 | Canon PIXMA iP1600 Printer
Service error 6000 Canon PIXMA IP4500
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 17, 2009 | Canon PIXMA iP1600 Printer
Where is the waste ink absorber on the pixma ip2200
Hi. I have researched on it and found that the procedure below resets the waste ink absorber most of the times and that too automatically. Hope it helps.
Canon Pixma iP1200, iP1600, iP2200 Resetter
  1. Download software for Canon iP1200, iP1600, 2200 Printers.DOWNLOAD Service Tool Software for Canon Pixma Printer iP1200, iP1600, iP2200
  2. Unzip downloaded file by WinZip, 7Zip, Izarc, etc
  3. Run GeneralTool.exe
  4. Select the connected USB port number from USB PORT
  5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
  6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selectedwaste ink counter will be reset. MAIN resets the main waste inkcounter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Mar 14, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
How do I clean out my waste ink on my Canon IP 2200 printer
Hi. I researched on this and found that these steps have fixed the problems most of time. Also, it does the required procedure automatically.
Feb 07, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
I have a Canon pixma ip1600 and it won't print. It just says service error 5100.
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
Jan 22, 2009 | Canon PIXMA iP1600 Printer
Canon Pixma iP1600- Service Error 5202
Silly as it my sound. But you did take the protective plastic cover off, didn't you?
Sep 01, 2008 | Canon PIXMA iP1600 Printer
Canon PIXMA iP1600 Printer Logo
96 people viewed this question
old marine
old marine
