Question about Balance CM2015 15" LCD Monitor
  • 149 Answers
Hi there, check your video cable, most of it has a broken cable. ty
Posted on Dec 26, 2007
Yellow screen
There are a variety of problems that can happen to the display monitor of an Acer laptop.
The most common problem is the screen fading or becoming too hard to see.
This can be corrected by adjusting the brightness levels.
Another common problem involves incorrect color, which can be resolved by adjusting the display color settings.
Yet another big problem is the display freezing or appearing jumpy, which can be resolved by updating the display driver.
Hold down the "Fn" key.
Tap the right-arrow key to brighten the display screen.
Tap the left-arrow key to darken the display screen.
Release the "Fn" key to save your display settings.
Right-click on the desktop and click "Graphic Properties."
Adjust the screen resolution by clicking "Display Settings" and choosing a resolution setting from the drop-down menu.
Click "Apply" to check the resolution of the display.
Click "OK" to save the resolution settings.
Adjust the color of the screen by clicking "Color Correction" and moving the brightness or contrast slider to the right or left.
Click "Apply" to check the color resolution of the display.
Click "OK" to save the color settings.
Click "OK" to exit the Graphic Properties application.
Update the Display Driver
Right-click on the desktop. Click "Personalize," "Display Settings" and "Advanced Settings."
Click the "Intel Graphics" tab and choose "Monitor Properties."
Click "Driver."
Click "Update Driver" and choose "Search Automatically."
Click "Install" to install the updated monitor driver. After the driver has been installed, click "OK" to restart the laptop when prompted.
Yellow screen
Yellow tinting in monitors can be caused by either a software calibration issue, bad cables or a worn out display and backlight.
Before you assume that the issue is a hardware one, determine if there are software settings that affect the color or if the cables are working correctly.
After checking these items, and if the yellow tint only occurs on one monitor and you cannot eliminate it, the problem is a display hardware issue and it is less expensive to replace the monitor.
Unplug the power cord from the monitor and replace it with another one.
This is a standard power cord used in printers, monitors and desktop PCs so you can trade it for a cable from another device.
Turn on the PC and monitor to see if the yellow is still there.
Turn off the computer and monitor.
Replace the video cable with another VGA cable from another monitor.
Use one from another computer before going out to buy one.
Restart the computer to see if the yellow tint is gone.
Right click any area on the desktop and click "Properties" from the list of options that appears.
Choose "Display Settings," then "Advanced Settings."
Select "Monitor" and click the "Calibrate Color" button.
Wait to see if the yellow tint goes away.
Locate the temperature color settings on the monitor.
Adjust these to see if there is a change in the color.
A warm color setting will give the screen images more of a yellowish tint.
Click on the "Start" icon, then click "Control Panel" and "System and Security" and choose "Device Driver."
Locate the video driver and click "Update."
Select the option allowing Windows to connect to the Internet to find an updated driver.
Wait for the update to complete in a few minutes.
Expect the yellowing issue to disappear.
Connect the PC to another monitor to see if the same problem occurs.
If the yellow tint does not appear on the newly connected monitor, the problem is a bad backlight or display and the monitor should be replaced with a new one.
Jul 21, 2013 | Acer Computers & Internet
Green tint on picture 60in mitsubishi
Turn the color all the way off---examine the screen to see if black and white or screen green in areas or whole screen.
The other possible issue is tint will not vary enough from green to purple when adjusted.
Two different issues--which do you seem to have?
May 31, 2012 | Mitsubishi WD-60737 60 in. HDTV
My dlp has turned yellow
ok, duplicate question posted here but other did not have model number--dlp with yellow screen is bad optical light engine.
Mar 24, 2012 | Televison & Video
Moved monitor and when I recionected monitor I have a green tint. How do I adjust the color back?
Please check all the pins on both ends of the VGA connector, more likely to have bent pins or not seated properly.
May 06, 2010 | Acer 22" X223w LCD Monitor
Yellow tint no color red.
you can adjust in color mode. please balance the tint, color,brightness, contrast, & sharpness.
Aug 30, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Mymonitor is an AOC 1770 CRT, it have a light
make sure you dont have a bent pin on the cable where it plugs in. a bent pin will make different things happen to your colors. if the whole thing is tinted, yellow, or purple it usually is an issue with the plug. also, if you have an old screen plug it in and eliminate the video card as the culprit.
Jun 19, 2009 | AOC 1770 17 in.
Color changed suddenly, no red, just green/yellow/blue
Sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel.
May 21, 2009 | LG 37LP1D 37 in. LCD Television
Mitsubishi tv problem
im assumiong you checked the tint in the menu options. if not go check it. other wise it sounds like you have a weak tube, or you do not know how to adjust the screen brightness. this is how i adjust the brightness (you dont need to touch the focus). turn the red up until your whole screen is tinted red, then do the same with the blue and the green. then go through each one and turn down just a little till your pic darkens a little. good luck
Sep 27, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Red tint on screen
Good Day,
Try resetting the TV by unplugging from wall outlet for 3 to5 minutes then plug back in. If no fixya take front grill off and panel and adjust the screen controls, turn color off adjust for Black & White Picture. Good Luck, big IRISH.
Sep 13, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Green color on Samsung ln-t4042
If the whole screen has this tint problem, there is nothing you can do. It must be repaired. You will need to take it in for service.
Mar 15, 2008 | Samsung LN-T4042H 40 in. LCD HDTV
Balance CM2015 15" LCD Monitor Logo
1,024 people viewed this question
Top Balance Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
