Question about Canon PowerShot SD850 IS Digital Camera
Time/date set What combination of buttons do I push to get back to the start up time/date set page????
Turn camera on
hit menu button
right arrow one time
and down 7
hit middle button which reads "func set"
then use the up and down arrows to adjust time and date
use the left and right arrows to move to next set
Posted on Jan 20, 2008
Watch Problems
PROVIDE US HERE THE WATCH MODEL..
AND ALSO PROVIDE A DETAILED PICTURE IF POSSIBLE...
Sep 17, 2008 | Watches
How do I change the day, date etc on a GENEVA 7391 watch
read the instruction manual, Geneva Watches with Two or Three Hands
  1. Pull the crown out until you feel a click.
  2. Turn the crown counterclockwise until you have the correct time.
  3. Push the crown back in to set the time.
Geneva Watches with Two or Three Hands and a Date Window
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the time.
  2. Turn the crown counter clockwise until you have the correct time. Push the crown all the way in to set the time.
  3. Pull the crown out until you feel one click. This first click position allows you to set the date.
  4. Turn the crown counterclockwise until you have the correct date. Push the crown back in to set the date.
Multi-Function Geneva Watches
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the day.
  2. Rotate the crown counter clockwise until you have the correct day. Push the crown in to set the day.
  3. Pull the crown out until you feel a second click to set the time or the 24-hour hand.
  4. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  5. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
Geneva Chronograph Watches
  1. Pull the crown out two clicks. This second click position allows you to set the time.
  2. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  3. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
  4. Stop and start the chronograph by pressing the PA button, located above the crown.
  5. Reset the chronograph by pressing the PB button just below the crown. The PB button returns the chronograph second and minute hands to their original positions of zero.
Automatic Geneva Watches
  1. Wind the mainspring by turning the crown 15 to 20 times clockwise.
  2. Pull the crown out until it clicks.
  3. Turn the crown counterclockwise until you have the correct time, then push the crown in to set the time.
Tips & Warnings
  • Do not set the date or time between 8 p.m. and 3 a.m. to avoid damage to your Geneva watch. The gears sit too close together during these times.
  • If your Geneva watch becomes wet, wipe it dry as soon as possible. Keep your watch away from saunas and hot tubs, as the extreme heat diminishes the watch's water resistance.
Read more : http://www.ehow.com/how_6134550_set-date-time-geneva-watch.html
Jul 13, 2015 | Geneva Watches
I dont know how to change the time on my decathlon geonaute watch
I nearly went crazy pushing buttons, but finally got the right combination. From the normal Time Display (as you would normally use the watch, no need to push any buttons) Push and Hold for a few seconds the Lap/Reset Button. The "Set" Mode will become active. Release the Lap/Reset button when Set appears in the Display. Notice in the Display a small Arrow that points to a button, either the ST/STP or Mode Button. (Initially it will be the ST/STP Button). When you depress the button to which the arrow points, the Field Flashing in the display will be set (For ST/STP) or Changed to the next Field (When the Arrow Points to the Mode Button). Simply toggle through the fields (using the Mode Button) and set (using the ST/STP Button) as needed. You will also be offered the ability to set the Month, Date, Day, 12/24 HR, and a M-D (It stands for Month - Date, in Europe it's more common to display as Date - Month). I did not change this field since by default on my watch it displayed M - D first. The setting cycle will be finished off when you have set the various fields by again pushing the Lap/Reset Button. Not related to setting the watch, but possibly useful, the Watch will completely reset if all the buttons are pushed at the same time, including pushing the Display Light (or in the case of this watch, the illumination used for the Display Characters). Hope this helps, it worked for me.
Nov 01, 2011 | Watches
I need set the time and date
TO SET TIME AND DATE, PUSH SIDE BUTTONS TOGETHER OR AT SAME TIME TO MAKE THE SCREEN OR FACE OF WATCH APPEAR WITH ITS TIME OR DATE, THEN GO TO OTHER SIDE BUTTONS TO GO UP OR DOWN ON THE TIME OR DATE UNTIL YOU GET TO THE PROPER TIME AND DATE. THEN GO BACK TO FIRST BUTTONS YOU PUSHED AND PUSH THEM ONCE MORE TO GET OUT OF THE SETTING MODE.
Feb 20, 2011 | Tag Heuer Kirium Formula 1 Chronograph...
Watch displays the wrong date. Maybe when I set the time back one hour something happened??? Don't know how to re-set the date.
Simple: from the default time screen. Push either of the right side buttons until you see settings.
From settings: Choose Watch.
From watch choose date set.
To get the complete manual visit my tips and tricks page.
Nov 08, 2010 | Polar F6 Wrist Watch
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Feb 13, 2009 | Bulova Watch
How do i set alarm on a gap sport watch?
For setting Time & Date...
1. Push "MODE" button three times (change Mode to TimeSet)
Time -> StopWatch -> AlarmTimeSet -> TimeSet -> Time ->...
2. Flashing Second Number Digits
3. Push "RESET" to select...
Second -> Minute -> Hour(12hr<->24hr) ->...
Date -> Month -> Day of Week -> Second -> ....(repeat)
4. Use "START" to set each item...
For setting Alarm ON/OFF
1. Push "RESET" button then Push "START" same time...
Alarm ON -> Alarm OFF -> ... (repeat)
Jan 09, 2009 | Columbia All Sport Digi Watch l
Operating instructions for timex t311t radio/alarm clock
You can acces a PDF file of the manual at the following site: http://timexaudio.com/media/uploads/product/files/T311IB57574_35.pdf
May 20, 2007 | Timex T311T Clock Radio
How do you set the clock/calendar on the Canon MP25DV?
on the bottom of your calculator is a reset button, with a paperclip or a pen press that button. Then, press the calendar, clock key. next, press the equal sign key until the date is flashing type in the date using 11172006. press the equal sign again and the date is set. Next press the calendar, clock key again the time should show up (12-00-00)press the equal sign again until the time starts to flash. enter in the time using 0903 (9:03) press the equal sign again. Time is set. to display the date and time when not using the calculator, press the calculator, clock key 2x's. to go to compute mode press the red CE/C button.
Nov 04, 2006 | Canon MP-25DV Calculator
Canon PowerShot SD850 IS Digital Camera Logo
54 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
