Question about Dishwashers
Admiral Portable Dishwasher - Fill and Drain Hook-Up Hose
Hello there,
I have an Admiral portable dishwasher which is approx. 4 years old. It was recently given to us. The attachment piece which is connected to the faucet does not have a stopper on the bottom. Once the water is turned on, the water continuously runs out into the sink. I believe we need to purchase new hoses... My question is: Where can we purchase these and can they be installed easily? Or would it be cheaper to have an appliance tech. repair it? We reside in Hamilton Ontario, Canada..... Please advise... Thank you for your time....
Regards
Earl
  • 1314 Answers
SOURCE: Kenmore 18inch Portable Dishwasher
how is the water flow at your sink this is a portable right un screw the connector at the sinkand check the screen 2 your fill hose could be kinking up when you pull it out take a light and look down into the washer see if you can see it kinked we will go from there
Posted on Dec 31, 2007
SOURCE: hose does not fit on sink faucet
Yes, the adapter was the answer!!! I went to the Sears Service Center and bought one, under $10. HURRAY! And say hello to softer hands . . .
Posted on Feb 15, 2009
Mrjtwright
  • 10 Answers
SOURCE: how do i connect a kenmore ultra wash II portable
You can get an adapter from a local hardware store. I'd come equipped with make and model number and the screw on screen retainer piece from your faucet.
Posted on Aug 21, 2009
Testimonial: "thank you for making this simple enough for a true blonde to do on her own"
SOURCE: Replacing drain hose of Haier portable dishwasher HDP18PA
how do i get to the hoses on maytag portable dishwasher
Posted on Jan 12, 2010
  • 10865 Answers
SOURCE: Replacement parts in Toronto
Hello. This is a common item and should be available from any plumbing supply house or appliance store. Call around. J.
Posted on Jul 10, 2010
Hose/ Adapters for older Maytag Portable Dishwasher
The sink faucet may have to be modified by installing an adapter.
Jun 22, 2017 | Maytag Dishwashers
What do I need to hook up my new portable dishwasher to my kitchen sink?
Go to a hardware store and get a Dishwasher Hook-up Kit. It will include a flexible hose along with several adapters. You dishwasher should come with a drain hose. You will also need a 3-wire "pigtail" (an extension cord with no receptacle or socket at the end). Your dishwasher whould have come with installation instructions, but seriously, if you've never done that before (or done similar work before), you should call a professional installer or at least and experienced handy-man.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 27, 2014 | GE GSC3500RWW Portable Dishwasher
Faucet solution for hooking up portable dishwasher
there is a generic adaptor that fits on your faucet; take the name, model# and, hose to a hardware store and, they can show you the right adaptor for your machine
Sep 15, 2009 | Dishwashers
Jul 27, 2009 | Haier HDP18PA Stainless Steel...
Kenmore portable dishwasher won't drain model # 665 17799990
Service person said is is not supposed to drain all the way. Something about it helps something not dry out.
Jun 24, 2009 | Kenmore Dishwashers
Maytag portable dishwasher is not draining
try to clean the filter by taking off the bottom section of the water jet, it might be clogged, if that does not work, u got the same problem as me, it just wont drain. The pump is probably broken.
Dec 05, 2008 | Maytag MDB9600A Jetclean II Built-in...
Older Portable Dishwasher
the bigger hose is the drain hose smaller one is the fill hose you can also look the model no. up on line like sears.com and order the hose assembly that has both hoses and the end hooks to the faucet
Mar 03, 2008 | Dishwashers
Dec 31, 2007 | Dishwashers
Installing my built-in dishwasher
the plastic drain hose goes either to the sink drain plumbing either to the pvc pipe or the disposer. there is a electrical junction box on the right side where you hard wire the unit in there is the inlet valve on the Left side of the lower axcess panels where you hook the water supply
Oct 01, 2007 | Admiral 24 in. DWUA800AA Built-in...
Dishwasher
I would put the dishwasher on its back so you can see underneath to check the fill and drain hose to make sure there not damaged in any way to cause it to leak. if it all looks good under there return it upright and remove the front lower kick panel grab a flashlight and start the dishwasher. you shoud be able to see a leak and where it is comming from. its possible it could be from the hose the inlet valve the pump and motor assembly or the plastic tub itself. good luck
Aug 04, 2007 | Frigidaire 18 in. FDR252RB Built-in...
Dishwashers Logo
431 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
