Scanner 4400F from Canon worked fine in the beginning but now I get suddenly vertical colored stripes always at the same location. Exchanging the scanner with a simular one from my dealer gives the same problem. Can it be software related?
I had the same problem- it went away after executing 'calibration' in the driver software. You have to open the driver window from the Canon Toolbox and press the execute button next to 'calibration'
When scanning in colour images, vertical lines appear at intervals on the scanned image. they don't...
(More)
When scanning in colour images, vertical lines appear at intervals on the scanned image. they don't seem to appear on b&w scanned items.
Canon CanoScan 4400f -- Havent used it in a while. Have a new PC - set up the scanner using the...
(More)
Canon CanoScan 4400f -- Havent used it in a while. Have a new PC - set up the scanner using the "set up" disk. The light is on the scanner - seems ready to go but it will not scan. (Trying to scan to a PDF doc).
slides are being scanned in as if they were negatives instead of color. this isn't consistent. it...
(More)
slides are being scanned in as if they were negatives instead of color. this isn't consistent. it will scan slides quite nicely and then all of a sudden start scanning the negative image. I am using a CanoScan 4400F
An image was repeatedly scanned with the Canoscan 4000f and now is always there without it being on...
(More)
An image was repeatedly scanned with the Canoscan 4000f and now is always there without it being on the glass plate. I have uninstalled and reinstalled the software. But to no avail. The image remains visible with every other image I scan.
