i assume you're having problems with (probably hot) water intake into your machine. if so- either hot or cold-or both). there are 'semi-circle' mesh inserts at both your hot and cold water connectors on the back of the machine- you'll need to move your machine, if needed to allow access to these connections (where your hoses screw on). then, if you have shut-offs for the water supplies to your washer, turn them off! expect a little leakage from the hoses! if no shutoffs- turn off main water supply and open up an outside faucet, until it drains down! you may want to unfasten the water lines to the washer, and keep them elevated for a while until the water drains from them! (after doing the previous things!) you'll see- in the inlet s a mesh screen, see if they're 'crudded up' with mineral deposits- if so, get a hat-pin or some thing similar and pry them out- use an old toothbrush to loosen any deposits you see clogging them, and tap them to remove deposits! perhaps place them in a vinegar solution to help dissolve them! when they're clean- replace them- re-connect water lines- hand tight- or a little more- don't break the nylon outside threaded connectors on the back of the washer, or your looking at a more expensive and tedious job! turn your shut-offs on, or your outside main shut-off, and hopefully, your drum will fill with great vigor!! don't forget your outside hose faucet, if you needed to 'drain' it down! if 'outflow'- drainage is the problem then it could be a small article of clothing, or junk, in your drain pump- could also be a failed drain pump- you didn't specify whether it was input or output. just guessed! good luck!!
Was this helpful?
Yes
No
Popular Solutions for Hoover AL120 Front Load Washer
machine takes in water intill the drum is full then drains taking soap with it than fills up again...
(More)
machine takes in water intill the drum is full then drains taking soap with it than fills up again the drum is then very heavy and make a screching sound and then drains again. put it on a second time and it washes but takes in very little water and machine will be on for an hour and a half.
Push button control panel has come loose and dropped inside the washer compartment. How do I take it...
(More)
Push button control panel has come loose and dropped inside the washer compartment. How do I take it off and reattach?
The door hinge has broken & needs replacing. I can get the part easily enough but do not know...
(More)
The door hinge has broken & needs replacing. I can get the part easily enough but do not know how to fix it to the door. I have removed the 4 screws close to where the hinge fits but am not able to get to where I need to be to get the broken bits out and the new hinge in. Any ideas??
Hi I have a Hoover AL120 machine which has developed a fault. As soon as the machine is switched on...
(More)
Hi I have a Hoover AL120 machine which has developed a fault. As soon as the machine is switched on - no matter what cycle is chosen or whether the dial is set to 'stop' - the pump runs and doesn't stop. Nothing else appears to happen. It is as if the machine is waiting for a signal from the pump to say it has finished pumping. What I really need is an electrical schematic for the machine - does anyone know where I can get one of these? Many thanks in advance M
Hoover 120 AL When I use program 4 the machine will not continue after reaching the stop sign...
(More)
Hoover 120 AL When I use program 4 the machine will not continue after reaching the stop sign between 4 and 5. If I turn machine off and move dial manually on to position 5 it will continue but stop at 8 or 9 . Turn it off and move dial manually it will continue to end of cycle
