Question about Sony MHC-GX555 Mini Hi-Fi System Shelf System
Sanyo mdg-x5 theres no sound through my t.v
0 characters
1 Points
Awm 660 bass
Does the manual list the part number of the remote? If it does you can search for a replacement on-line. If you are from the UK Curry's Partmaster has a good range of Sanyo remotes.
Sep 02, 2013 | Sanyo AWM-660 CD Shelf System
I have a cd changer player Sanyo md cp-1770. connected to my stereo receiver, but no sound coming out, although it shows it is playing, what do you think is going on?
Close, but not EXACTLY a modl lnumber or how it's connected. What output to what input? Is the proper source selected? Does it work withg its onboard FM. Clues, please.
Aug 04, 2010 | Sanyo Audio Shelf Systems
CAN i purchase speakers for sanyo da 1000
Unless you want the same speakers for cosmetic reasons, you can get a pair of speakers from any Hi-Fi outlet. All you need to know is the max power output of the amp in watts for each channel, and the ohms it puts out. For instance if it says 8ohm 15 watts. You can get a speaker of 8ohms or higher, but not lower. And any speaker above 15 watts.
Actually you can get better quality sound from the speakers as the speakers they often put with these systems are rubbish in terms of hi-fi quality!
Just had a look around the net and the output power in watts is just 8. Couldn't find the ohm rating but most are 8ohm. So any speaker higher than 8 watts will do the job.
Feb 10, 2010 | Sanyo Audio Shelf Systems
The belt that rotates the cd tray is broken. How
Belts are measured by diameter and thickness. Some are sold on places like E-Bay, if you have no luck there you can try Chas Hyde & Son Ltd, they do have a website, they are also an authorised parts distributer for Sanyo.
Dec 12, 2009 | Sanyo AWM-2800 CD Shelf System
Sanyo dmp p8 ipod
Found the manual on the Sanyo Australia site
Apr 17, 2009 | Sanyo Audio Shelf Systems
CD unit unit displays ''No Disc'' when there is a disc in slot 1
What does it do if you put 3 discs in and select each one? You don't say what it does with the other two trays. It would help to know that they work. If not, you have a bigger issue. Let me know.
Apr 03, 2009 | Sanyo Audio Shelf Systems
Clock set instructions for Sanyo stereo awm2800U
you need the remote to change the clock press timer am 1200 blinks press timer again for at least 2 seconds the hour blinks press tuning/time set plus or minus press clock adjust the minute will blink press time set to adjust minutes then clock adjust there you go...
Mar 10, 2009 | Sanyo AWM-2800 CD Shelf System
Sony MHC-GX555 Mini Hi-Fi System Shelf System Logo
23 people viewed this question
Top Sony Audio Shelf Systems Experts
Are you a Sony Audio Shelf System Expert? Answer questions, earn points and help others
