Question about Sony Playstation 3 (PS3) Console
Hi I recently played my ps3 on my friends tv using an hdmi lead and all was fine. Now i have returned home and tried to play my ps3 without the hdmi lead and it wont work can you help please.
  • 182 Answers
Go back to your friends with your ps3 and change the tv settings on the ps3 back to scart output but also take your scart lead and have it plugged in at the same time. once you have selected scart output unplug the hdmi cable to make sure the settings are right. hope this helps you.
Posted on Jan 07, 2008
  • J4XXN
    J4XXN Jan 08, 2008
    hi ive just found out when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option
How do i connect my technics sh-dv290 to my tv and what leads do i need
i am trying to do same thing - i suggest connect ps3 via optical cable to hi fi red/ white cables via a optical/ rca adaptor, the ps3 is connected to tv via hdmi so play dvd via ps3 sound will play through hi fi - but remember dont need the yellow dvd cable from hifi dvd player to tv any more as you will be using the ps3 as a dvd player instead
Jan 02, 2013 | Technics SC-DV290 System
I played my ps3 for the first time using my old tv(no hdmi slot)..then i try to play at my second tv (hdmi tv)& surely can play successfully.. but the problem occured when i played for the third time...
Hello,with the unit turned off press and hold down the power button till you hear the second beep then let go,about 8 seconds later video should return to the older tv.
Feb 21, 2011 | Sony Playstation 3 (PS3) Console
My son recently took his playstation to a friends to play. Friends TV did not have HDMI connection so used the scart lead. In order to get it to work we had to hold the power switch down to "OFF"...
well this a common problem and the solution to the problem is as follows:
Turn off the power to your PS3 and then turn it back on again. But when you turn it on, hold down the power button until you see something on the screen. When you hold down the power button of the PS3 when you are turning it on, it completely resets the video settings to the most basic settings (480p I think) so that it'll work on any TV or monitor. Once you can then get something on the screen, you can configure the video settings to match the TV you are hooking up to.
hope its helps, thanks
Jan 11, 2011 | Sony Playstation 3 (PS3) Console
Problems with HDMI. Screen goes 'blank' whilst playing game. TV claims to be not receiving any signal. play with HDMI cable at back of ps3 and picture returns... Is this my ps3 my HDMI cable or my...
I have the same problem but i changed my hdmi lead for a more expensive one from comet and its fine now! so proberly just a rubbish HDMI lead i bought mine on ebay for £2.99 :-( Not such a bargain.
Dec 10, 2009 | Sony Playstation 3 (PS3) Console
Hello can you help with this error!
When you switch from one cable connection to another (Hdmi to AV etc) you need to reset the PS3 to its default settings. Basically what is happening is, your PS3 is set to HDMI, so when you plug in AV cables it doesn't know it. So you have to reset it. Hook your PS3 up to whatever cables (make sure system is fully off) then hold the front power button down for a few seconds.
Doing this will reset the display settings. You can then go into the XMB (main menu) and choose your connection. Although the PS3 should do this during the start up on its own.
Hope this helps.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
Scart to HDMI
press and hold your power button for a few secs until it beeps, do it again.This resets all of your settings.You just need to set everythin right again
Aug 20, 2008 | Sony Playstation 3 (PS3) Console
Hdmi
The HDMI lead only carries the video and audio from the HTS6510/05 to the TV.
The scart carries audio and video both ways.
Re-connect the scart lead and all will be ok.
N.B. When the HTS6510 is switched on, the TV will auto-switch to the scart input. You will then need to switch the TV to HDMI to get the benefit from the DVD upscaling.
Feb 02, 2008 | Philips HTS-6500/37 System
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Lcd montior with tv box but no hdmi sound
in some cases certain manufacturers say in the instructions that when using s video with seperate audio, you cannot use the HDMI for the sound and sometimes visa versa, it's just the way the output is set up. Remove the other sound cable you are using for pc or tv and just use HDMI to confirm that the sound is re-enabled on the HDMI
Oct 02, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
198 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
