Question about Lucent PARTNER18 Corded Phone
One line doesn't work at all
One line doesn't work at all.
Please help
  • mufflers Jan 11, 2008
    1 Phone line rings but it cannot be answered because i need phone reprogramed
  • Anonymous May 23, 2008
    I have six lines in my office out which three lines are not working from
    16-05-08 I made daily complaints & after six days when made a lot of request one lineman came & he fixed it but after two hours all of six lines are dead when i called the bsnl dpt they said we are not here for just you call us tomorrow plz help me as i have fast food business all my business comes through telephones plz do the needful.
    Sudesh Kumar
    Dominos Pizza Ind ltd
    ph nos 2723262,2723263,2723264
Line a line is dead? At the system you will see a port labeled line 1 and a port labeled line 2. swap them. That will prove if the line is dead or if the port of the system is dead.
Posted on Dec 29, 2007
  • Anonymous Jan 11, 2008
    Well moron.....if it rings and you cant pick it up...THERE IS A PROBLEM. DONT POST NEGATIVELY for people that are trying to help you..
Ac doesn't blow in front vents but works everywhere else how can I fix
vacum line off or cracked from intake manifold to vacum controller under dash. to test under dash buy cheap vacum test from parts store conect tovacume port underdash pump up and with ac running you will gain control of vents. take your time and researh location of vacum line. good luck
Aug 12, 2012 | 2003 Lincoln Navigator
Ice melt, water coming from ice tray onto the floor. After clean, found ice maker doesn't work at all. Please help.
Clogged drain line! Look in the bottom of the refrigerator for a drain hole or check in side your rear panel on the back Ref.
Sep 16, 2011 | Refrigerators
How do you feed the string into this weed eater? I've tried several ways - actually, my handyman has!, without success. Help please!
Hello gaelic light!
Sorry to hear that you (and the handyman) are having issues, and I really hope that this helps, but without the brand and model number, there's no way to be more specific! Is there any way you could re-post your question and include this info?
Normally there are only two types of line discharging mechanisms, those for continuous feed and those for static feed that use a heavy duty type of line that doesn't move. For each of these mechanism, there is a different installation method.
For the first, on most models the entire line holding unit will release when you unscrew the bottom "button" that is usually bumped in order to release more line. After it is unscrewed, you simply add more line onto the spindle. It should tell you the direction to wrap it on the unit itself. After both (if it's a twin line unit) have been loaded with line and the ends have been fed through the holes, you replace the cover, slide it back on and then replace the screw, or "button".
For the second type, many models these days make them so that they automatically "grab" the new 10"-12" piece of line when you simply shove it in the slot.
Again, I'm sorry that I am not being more specific, but as I said, if this doesn't help, please re-post your question and include your brand and model number.
Thanks and Happy Trimming!
Jul 17, 2011 | Garden
Please help me. I'm seeing a red and a green line on my sony vaio laptop screen. The red line was appearing from last one month. And the green one is appearing from yesterday. I want to remove those...
If this line is contineous then it would be a screen damage to your pc but if line doesn't appear all the time or screen flickers on a particular area of lcd or completely, it might be data cabel issue with it.
Jun 24, 2011 | Computers & Internet
Turn signals and horn not working
check the battery if it still ok
check each each bulb and circuit line of the signal lights as well as the horn too...
* might be some shorted or cut lines in the electrical thats why it doesn't work...
hope it helps...
Jun 04, 2011 | Suzuki GSX-R 750 J Motorcycles
We have a kenmore humidifier on the furance model # 48945. it doesn't stop running so our water bill is twice what it should be. I've tried to find a manuel on line so i can figure out how to...
Noodles, it sounds like the float valve inside the water reservoir is stuck in the down position. Turn the water line ON/OFF valve to the humidifier OFF. Open the top of the reservoir and you will see the float valve. Gently, lift it up, to see if it will remain at the top of the water level, which left in the reservoir. It it doesn't, then the float needs to be replaced. In the mean time, leave the water line ON/OFF Valve OFF.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 07, 2011 | Kenmore Humidifiers
My printer doesnt work it doenst switch on at all
If printer doesn't work and it doesn't switch on, I assumed that there is no power at all on the printer. Check the AC line voltage if it is correct.
Unplug the printer. Remove the LVPS/HVPS, and check the fuses for continuity.
• If open, then replace the LVPS/HVPS.
• If not open, then check the switch continuity across its conductors with the switch on.
Turn the switch off. Plug the AC line into the LVPS/HVPS, and switch unit on.
Please try reseat power cable. If this does not resolve the issue, you may need to replace the LVPS (Low voltage power supply) on your printer.
For further assistance, please contact Lexmark Technical Support
Feb 07, 2011 | Lexmark E260 Laser Printer
Line 44, char 8862, handler already exists,URL: always appears lately and now i cant access farmville but i can play around with fishville......
line 44, char 8862, handler already exists,URL: always appears lately and now i cant access farmville but i can play around with fishville... please help me to rectify this...
Dec 06, 2009 | Facebook Social Network
Lucent PARTNER18 Corded Phone Logo
191 people viewed this question
Top Lucent Lands Phones Experts
Paul C.
Computer Repairing
Computer Repairing
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
