Question about Nextar MA833A-BL MP3 Player
HELP my player wont switch modes when i press the button
0 characters
1 Points
My Sony Walkman NWZ-A818 wont switch off Connecting to the PC I can see the device in explorer and delet items but the device is in limbo in that I cant switch it off from the welcome screen
To turn the portable player ON, with the HOLD switch in the OFF position, press any button. To turn the portable player OFF, press and hold the OPTION/PWR OFF button. The player will enter the STANDBY mode and the screen will turn OFF to save battery power. If the standby mode continues for approximately one day or more, the player will automatically turn OFF completely.
If the Player still doesn't turn OFF, Reset the Player by pressing the RESET button on the Player using a Sharp pointed object for 3 seconds. The RESET button is located next to the STRAP hole. The RESET button is a small hole.
I hope you find this information useful.
Thanks and Regards,
Nov 07, 2010 | Sony NWZB133F MP3 Player
Wont play the whole song
Sounds like the player is running in INTRO mode, only playing the first part of each song. To change playback mode, follow the steps as described below.
Switch the player ON and start music playback:
1. Press PLAY button to START music to play
2. Press PLAY button again to PAUSE the playback
3. Press MODE button to enter playback mode selection
4. Scroll with MODE button through selections
5. Press MODE button when selection REPEAT is in the display
6. Use MODE button to select from: Normal, Repeat One, Repeat
within current Folder (if any), Repeat Folders (if any), Repeat
All songs, Random Play back, and Intro
7. Press MODE button to confirm selection
May 02, 2010 | Element Electronics GC823 MP3 Player
My sandisk sansa clip 1gb wont turn on
Make sure the player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 29, 2010 | SanDisk Sansa Clip MP3 Player
How do I get My e260 in recovery mode, it wont even come on?
1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player. I do not think your model supports the recovery mode but you can try. 1. Press and hold the Power/Menu button for 15 seconds to turn the device completely off. 2. Slide the Hold switch so the orange portion shows. 3. On your PC, double-click My computer 4. On your Sansa player, press and hold the REC button while connecting it to the PC. 5. Release the REC button when a 16MB-FORMAT drive partition appears under My Computer. This may not work on your player not sure of the Model cut off.
Jan 16, 2010 | SanDisk Sansa e260 MP3 Player
I have an element mp3 player and i don't know how to turn it on or off i am way new with this whole thing and i really need help please help me.
Hey, I just got one of these as well. They're kind of.... not the best ;) .
Anyway, to turn it on, press and hold the large circle button (play) until the element screen comes on. Then press the "mode" button to get to music. Remember that there are only the "mode" button/switch and the "play" button to switch functions. The other two buttons don't do much.
Dec 26, 2009 | Sears GC-820 MP3 Player
GC-822 Buttons Just Change the Color
After a mode is selcted by moving the mode slider switch left or right then depress that same mode slider switch like a button. When the mode switch is used to change a mode but one does not press it in to select it, that is when the play button changes colors.
Sep 20, 2009 | Sears GC-820 MP3 Player
80g ipod classic won't unlock or charge,and itunes won't
My 80GB Ipod classic recently froze. I took it to Apple store and the guy press the Menu and Center Button. Hold them until the APPLE logo appears twice. Then release the button.
Voila, my Ipod work again, no missing data
Jul 22, 2009 | Apple iPod classic MP3 Player
Wont change back to mtp
. On the mp3 player, switch between the Usb and Mtp mode (The M button) on the side of the player.
May 17, 2009 | GPX MW3837 MP3 Player
Sansa e280 Main Image Wont Load Problem, Plus firmware updater doesn't work
Do not worry! I had the same problem as you before and got it fixed perfectly! Go to this thread and read the instructions carefully.
Note that doing this will delete all files in your player, so I recommend you to save your files somewhere before doing this.
Dec 28, 2008 | SanDisk Sansa e250 MP3 Player
Hardware wont install
I had the same problem with my e260 4GB player. To upgrade the firmware to enable setting USB mode to MSC, try the following;
1. Slide the hold switch to the locked position by sliding switch at the top of the player towards the headphone jack until you see the orange indicator.
2. Press and hold the << (rewind) button.
3. With the << button held down, connect the player to the PC.
Once I did this, the firmware was upgrade, the USB Mode command was available in the Settings. I switch to MSC, plugged in the player again, and now Windows recognozes it.
Nov 28, 2008 | SanDisk Sansa e200 MP3 Player
Nextar MA833A-BL MP3 Player Logo
16 people viewed this question
Top Nextar MP3 & Digital Media Players Experts
 Mike M
Mike M
Joseph Hoffmann
Are you a Nextar MP3 and Digital Media Player Expert? Answer questions, earn points and help others
