Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Water dispenser isn't working
I have a GE refrigerator side by side. the ice works but not the water. I took the filter off and emptied then put it back on. It filled back up but still no water will come out. Can you give me somethings that might be wrong. Thanks alot,
Mike
  • Anonymous Mar 23, 2008
    Noticed small puddle of water on floor under ice/water dispenser ( freezer door ). Ice dispenser is working, no water. Water is present in visible line under door. Also, noticed ( today ) freezer isn't keeping items frozen ( freezer setting has been 4 1/2 ).
    Have no idea where filter is located, hasn't been changed for years, perhaps never. Frig is appx 5 years old.
    Have no book or diagrams on this frig.
    Scholar:
  • 146 Answers
Remove your meat pan in the refer and check the dispenser. It may be a reservoir type or just a coil of tubing. Check and make sure water is coming into the tube. There is a place to check sometimes at the bottom of the refer door. Sometimes there is a connection that can be taken loose to check and make sure water is making it to the door. Check that. If your filter is a year old replace it. I'm sure it needs it. Check those possibilities then check where the water comes into the refer. Trace it to the solenoid underneath the refer then make sure the solenoid is opening to allow water through.
Posted on Dec 26, 2007
Water dispenser ice maker
If you check the backside of your refrigerator...
There are TWO (2) different electric water-valves...
A generic WHIRLPOOL part number = wr57x10032
(typically you can hear the "THUMP" when the are working...
WATCH this attached video...
http://www.appliancepartspros.com/ge-water-inlet-valve-wr57x10032-ap3192626.html
Hope this is helpful...
Carnac the Magnificent
Dec 07, 2017 | General Electric GSH25JSXSS Stainless...
Ice Maker working, but water not dispensing
There are two sides to a dual water control valve. One side fills the ice maker and the other side is the dispenser. If one side goes bad you will need to replace the whole dual water control valve. If your model is the GSL22JFXLB your replacement is the=> WR57X10032 Water Inlet Valve
This part is found on the rear of your refrigerator near floor where the water from your home hooks up to your refrigerator, Thanks Sea Breeze
Mar 08, 2013 | GE GSL22JFXLB (22 cu ft) Side by Side...
The water dispenser won't work, but the ice maker does on my side
try putting the hair dryer on the door where the water and ice comes out. then put it in the hole inside where the ice falls in. only took me 20 seconds for water to work
May 19, 2009 | GE Refrigerators
GE Profile Refrigerator water dispenser stop working...
This could be a bad water valve on the back of refrigerator or the dispenser is not asking the water valve to open. There are 2 valves in back, one is for ice maker and other is for the dispenser. I will help to try to locate the problem if you need, let me know, Thanks, Sea Breeze
Mar 26, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Jan 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Ice maker not working
The machine water pressure is low cheak the inlet water pressure and cheak the machine water in let line any block
Jun 21, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
Water/Ice Dispenser is not working
at the very least replace that water filter.clogged water filter will reduce water pressure to the line.
Feb 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
48 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
