With ATX connector disconnected all the power supply voltages are OK and all the fans are running. ...
(More)
With ATX connector disconnected all the power supply voltages are OK and all the fans are running. When ATX connector is plugged in while all the above is true, it shorts out and cuts the power off. The power recovers and runs as before. When the ATX connector is plugged in along with all the other connectors, the power does not go on. The 12V ports on the ATX connector show 11 ohms, the black wires are properly grounded.
Is it practical to try and trace the circuitry on the P4 Titan 533 motherboard or should i just replace the motherboard itself?
buenas noches, temgo una board msi_k9mm_v_ le acabo de cambiar el hd tenia uno de 250 gg y se lo...
(More)
BUENAS NOCHES, TEMGO UNA BOARD msi_k9mm_v_ LE ACABO DE CAMBIAR EL HD tenia uno de 250 Gg y se lo cambie por uno de 320, tambien la desarme totalmente y la limpie, ahora que la volvi a armar, la CPU prende, las unidades de CD abren y cierran, pero el monitor se queda en negro, no da ninguna señal y cuando la reseteo no apaga, he revisado mucho las conexiones que esten bien y no encuentro el rpoblema, me pueden colaborar por favor? gracias LILIANA
I just bought a abit kn8 sli motherboard from an auction. I only have one video card so I need the...
(More)
I just bought a abit kn8 sli motherboard from an auction. I only have one video card so I need the abit shadow card for the PCIXP2 slot. Where can I get this?
could you please describe the m2v sound output plug spec for 5.1 socket as fitted to the asus m2v...
(More)
could you please describe the m2v sound output plug spec for 5.1 socket as fitted to the asus m2v motherboard. also as to the 3 other sound sockets and their use. thank you, from bern
