TV seems to be stuck in mono
I have a goodmans LD3201 TV and the display in the corner of the tv is constantly on mono. I have tried altering the settings for sound on the menu but there does not appear to be an option for changing sound to nicam although there is a box next to the mono one which is unlit. This is driving me scatty as I have now brought a home cinema set which also will not work on this TV but will work with others in the house straight away. Please can anyone help me as I have trauled the internet with no luck looking for a clue!! Thanks
  • 17 Answers
SOURCE: Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Posted on Dec 31, 2007
  • 367 Answers
SOURCE: Sound no picture brand new tv
I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
Posted on Feb 02, 2008
  • 138 Answers
SOURCE: Sky remote code for JVC GM-P420E
Go to www.remotecentral.com
Posted on Aug 19, 2008
dsacco86
  • 1077 Answers
SOURCE: My Sharp TV will only hear sound. No picture or images even from the tv menu setup option. Model# LC-19SB25U. About 1.5 yrs old. Converter box ok.
In most cases, you can reset the TV by leaving it unplugged for 30mins.
If this doesn't work, I believe the circuit board that supplies power to the screen maybe bad. They call this board a backlight inverter board. It would most likely cost more to repair than replace the TV .
Posted on May 27, 2009
SOURCE: Small black box in upper left corner of Sony TV - need to remove
I had a similar problem on my Toshiba Regza but trying my fix couldn't hurt. I use a satellite dish for TV (if you do the same this might work)... I turned off my receiver, took the programming card out, cleaned it with my shirt (especially the part that looks like a computer chip), put it back in the receiver, turned it back on and when everything reinitialized the black rectangle was gone.
Hope this helps.
Posted on Apr 13, 2010
Instruction manual for ld3201
Type in details google search or other, should come up with manual
Aug 10, 2014 | Goodmans GTVL32W27HDF 32 in. LCD TV
Can't change from MONO to AUTO mode
Hello
Can't make sound from mono to auto is your problem I thinks and posts this solution.
Hit the "Menu" button and surf through, come to "Sound Adjust" window.
The settings allow you to change and adjust sound in your TV. There are Bass, Treble and Balance control to adjust to your individual taste.
To adjust them
1. Press Menu button.
2. Press UP or DOWN button to select the desired item.
3. Press => or 4. Press EXIT button when finished.
When adjusting the parameter of "Balance" control, always set it to mid position to get stereo sound from both speakers. If it is set to any extreme end, there will be no output from the speaker of that side, and will hear as mono.
If you press "0" [Zero] button, you can reset the sound settings to it Factory settings.
To select 'Streo mode;
1. Press "Menu" button.
2. Press UP or DOWN button to select MTS [Multi-channel Telivision Sound].
3. Press => or [The ON AIR arrowtells you if a broadcast is in stereo AND/OR contains the SAP.
Press "Exit" button when finished.
Keep the TV in stereo mode to get the best sound quality. The sound will work in stereo
mode even if a certain broadcast is in mono sound only.
Choose the mono setting to reduce excessive noise on a certain channel or broadcast.
Selecting SAP will allow you to hear an alternative soundtrack, if one is available.
Apr 01, 2011 | JVC AV32F476 32" TV
Sharp Aquos LC-32D44U stuck in ""Mono"
I dont know if this will work for you, but its worth a try. I had the same problem.
1. I changed to a station that was having the problem (an analog station with MONO displayed on the screen).
2. I unplugged the TV for about 15-20 minutes. (I was thinking maybe something needed to refresh, so thats why i unplugged the tv.)
3. I plugged the tv back in and voila. The station showed up as MONO then immediately swtiched to STEREO.
After that, i was able to use the AUDIO feature on the remote to actually change from MONO to SAP, etc.
Ive had my Sharp for about 5 months now, and thats the first time its happend to me. Luckily, i solved the problem...this time.
Hope it helps.
Feb 12, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Constant channel display
Press Info " i " or may be Display button on Tv remote, on-screen display will disappear.
Jan 03, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
'03' is displaying on my screen
First try, using the remote, pushing the display button until the display is turned off (three to four depressions on the remote display botton. Second try, unplugging the tv for at least 2 minutes then plug the tv back in. This should reset the tv if you have lost the original remote with the display bottton.
Dec 30, 2008 | JVC AV-36260 TV
My volume display stays on
The Tv needs to be serviced by a technician.Probably there is a problem with the circuits inside.
Apr 12, 2008 | Televison & Video
Using 2 Pc speakers on my Tv
1)probable incompatibility issue--for comparison did you try a set of headphones? 2)The RCA audio outputs on the tv can go to an amplifier that has speakers attached,ie surround sound. 3)Caution==never try to alter vol level at spkr!
Oct 02, 2007 | Toshiba 27DF46 27" TV
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
