Question about Microsoft Xbox 360 Console
E 76 Seems to be a ethernet controller problem can it be fixed?
  • 29 Answers
Sorry to be the bearer of bad news but there is no quick fix for this issue.
You have basically 2 options.
1.  Crack open you 360 and check reseat the card or
replace the ethernet card...easy to do and
the part is available online but cracking the box will void any
warranty you have left so unless you are out of warranty
I don't recommend doing this.
2.  Send it back to  Microsoft for repair.  If it is under warranty they will repair it for free (just the cost of shipping and handling).  If it is not under warranty they will generally repair it for 99.00.
Best,
Bob
Posted on Jan 12, 2008
Remote is flashing C8 and 76, alternating. I turn the unit off, then back on, and I get hot water for about 10 seconds, then it goes cold and the same error message occurs. Unit is Rheem Main Remote...
Before calling service technician, open following links for Rheem tankless resources including error codes and Rheem chat.
Disconnect wires from remote to see if system stabilizes. Unit will heat to default temperature without remote.
Error codes are considered start-point for troubleshooting.
C8 76 can mean PC board failure.
76 can mean communication failure with remote control
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
Jul 31, 2011 | Rheem Tankless Water Heater Main Remote...
My xbox 360 says error 76 and dont know what to do.
Error code 76 is a problem with the Ethernet controller chip problems or something else involving the Ethernet chip. If your Xbox is still under warranty send it in and get it repaired. If your warranty has ended then there is nothing stopping you from replacing it yourself. If you search around there should be some step by step guides to show you how. If the xbox is working fine otherwise...just let it go and play on.
Apr 28, 2011 | Microsoft Xbox 360 Console
I have a Rheem tanklees water heater, model RTG-74XN-2. The remote shows the following error code. C4 then the number 76 then C4 then 76. What does this code mean??
Contact Paloma/Rheem 866-720-2076. Super nice! I just called regarding mine. Having same problem Rheem Paloma sending parts out tomorrow overnite. Try turn it on/ off by moving tiny switch under the unit that tells you the temperature. Run your fingers along the bottom to find it. That is a temporary fix. Below is a website with all the error codes, so you know what is wrong. Good luck and blessings!
http://www.palomastore.com/paloma_error_codes.html
76
Communication Fault with Remote Control Check remote control wiring for loose or damaged connections. Bypass remote control cable by connection remote directly to remote control terminals on PCB (replace cable if found to be faulty). Replace remote control. Replace PCB
76
76
76
Nov 06, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Oster Blade 918-306 Size Texturing Fits Oster Classic 76 Clipper, Power Pro, Power-teq And Star-te: Oster class 76 clippers....had them for a week and...
70ca16d.jpg Hope this helps, this is a tongue guide, you hopefully recognise it on your blade. If they are not paralell, then adjust them with pliers, both need to be perfectly vertical. When you put it on the clippers push the latch in as you close the hinge.
If it still wobbles then the next fe wthings need checking
1. The hinge screws on the clipper are tight, located either side of the hinge on the clipper.
2. The drive lever may be worn, thats the maroon peice of plastic sticking up at the top of the clippers, it moves from side to side when clippers are running.
3. If all seems fine up to now, your clipper should be fixed under warranty as it will involve changing parts covered by the warranty.
www.sheareaseltd.com
May 17, 2010 | Sunbeam Oster Blade 918-306 Size Texturing...
E 76
Just try searching RROD in google and you'll find exactly wat you need to fix this problem, best of all most can be downloaded for free and u will only need a set of small screw drivers and torx bits and the repair kit from ebay will cost you between £2 and £3.
Mar 27, 2010 | Microsoft Xbox 360 Console
Our Lasko 5620 has a digital control, but we can't set the temperature. It says at 76 degrees, no matter what we do. Hitting the control buttons does not work.
Based from your comments, it seems that you have a
defective digital control. Have a check up for this item.
It may need to be replaced. Hope this will help you.
Jan 10, 2010 | Lasko 5610 Baseboard Heater
C4 76
76 is a bad connection between the controller and the unit. try unplugging the controller and running it, also check the wiring between the two units. if that is not it. it means that one of the control boards it shot
Jul 18, 2009 | Water Heaters
Starview 1 no repairs
codes for box give you a few as u never stated you provider hope this isof help..
ntel.
0. 3F B8 36 62 72 E5 E2 76
1. 35 5E D6 40 6E AA 99 41
tw
0. C0 F6 61 87 91 F9 67 57
1. F0 83 35 E5 28 40 49 B2
cw.
0. D4 A3 5D EB 7B F3 69 59
1. 27 77 A1 FC 8F 9D 34 76
Dec 09, 2008 | StarTech.com StarView SV211K 2-port KVM...
Xbox 360 system error E 76
I got it when it was thunder when a flash hitted our house or something. My power connector was unplugged but the internetwire was plugged in the Xbox 360. So probably it´s a Network card wrong...
Im going to call my shop tomorrow and hopeful i´m going to get a new one on warranty :)
Mar 04, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
