Question about Compaq Evo N410C Notebook
The base i cant seem to get the base off my laptop. i normally press the blue button on the right hand side but its not doing anything - any suggestions?
    Genius:
  • 1,601 Answers
How can i go to control panel when cursor wont click on anything
Press the windows button on your computer keyboard, this is normally located on your bottom row of your keyboard to the left hand side near the Ctrl and Alt key some keyboards have 2 windows keys.
This will bring up you start menu now use your 4 cursor keys with arrows on to navigate to and highlight the control panel button and press Enter. If this works you may have a problem with your mouse, if this dose'nt work you may have a problem with your operating system or a progam installed.
Jul 17, 2014 | Acer Computers & Internet
Toaster won't turn off
its broken, retun it to the place you brought it and demand a refund
Nov 22, 2013 | Russell Hobbs 18117 4-Slice Deluxe Toaster...
Is the button that enables/disables the touchpad next to the on/off button on the right hand side? And how do I know if it is on or off?
Normally on an HP computer the on/off button for the touch pad is directly above the touch pad. Off will be a red or amber, on will be blue.
Mar 16, 2012 | HP Pavilion Computers & Internet
When i push the e,b,t,a,n ,or r button on my keyboard i get e3 ,bt5,a1, r is shif and nyt
I have often deal damage keyboard, and type of damage keyboard so much. For damage your experience, a variety of ways have been tried, but the result always failed. The best solution is replace keyboard.
Based on experience, three times I fix keyboard, without having to replace with a new keyboard.
First type of damage
All keyboard keys are not functioning, or functioning left side, right side not working
Solution
Remove the keyboard, and cut keyboard cable.
Second type of damage
When laptop is powered on, the sound (tiiiiiiiiiiit) so hard. When we press a button, suddenly appeared equal. example;
I press "y", y appears =======================
I press enter, appear =======================
Solution
Press and release button ~ ` , do it
repeatedly, when turning on laptop until laptop access the operating system.
The result is
1. When laptop turned on, there was no sound. Laptop turns normal.
2. When I press buttons, does not appear equal to. So all buttons normal function
3. There are three buttons that do not function [ { , ] } , \ '
Third type of damage
When laptop is powered, it looks normal. After entering the desktop, buttons z, x, a, s, q, w, e, does not work. If another buttons is pressed, appear equal. example;
I press p, appear p=======================
Solution
Do not turn on laptop (about 3 weeks)
This solution does not make sense, there is no technical explanation, and this solution so strange.
The fact that I experienced
This case occurred on the Acer Aspire 4736z, OS Win XP Prof.
After laptop not turned on, more than 3 weeks, keyboard returns to normal. All buttons are functioning normally. I can not explain technically, but this case never happened.
Solutions for you
I hope this information useful.
Dec 04, 2011 | Toshiba Computers & Internet
How do I switch the bluetooth on on my U90?
it should have a button on your machine. locate it on the side and switch it on.
Jun 30, 2009 | Computers & Internet
I have a paper jam on a HL-5040 where I can see the paper under the toner/drum. The Brother site suggests pulling the paper up and out once the paper tray is removed, but my sheet of paper won't budge at...
I consulted the Brother site again but this time I researched just how to remove the drum. This page has nice drawings that show how to just pull it straight out! They explained the blue button on the right is just for holding the toner in the drum. They also showed, a very important piece of information, where to place the hands as well. I did it slowly because the jammed paper seemed to be 'stuck' to it. It came out easily, with no real force required. I removed the paper and slid the drum back into place. Quite simple once I could see how to do it without risking damage to the printer!
Apr 08, 2009 | Brother HL 5040 Laser Printer
Laptop is turning on-but everything seems frozen
If you have a second set of functions on the buttons that are in blue or another color they may have been turned off. My kids like to play with my notebook and they did that. Just hold the function button (mine is blue and labeled 'Fn') I just hold that and press the button that corresponds with my mouse (a pointing hand in a rectangle).
Other than that I dont know what would work.
Sep 01, 2008 | Acer Aspire 5610-4648 Notebook
Maxdorf tv
Press and hold the music button until the normal picture appears.
Jun 19, 2008 | Apex Digital AT2008 20" TV
Signal indicator flashes constantly
The following worked when I had what appears to be the same problem. Solution :- Remove batteries, remove power connection, wait 30 minutes, re-connect power and replace batteries then press button on base until it beeps. Both handsets started continuous beeping which eventually stopped and everything was returned to normal. Admittdly this sounds almost identical to the process used by 'versailles' above, but at least it confirms that the technical info given by the BT Helpline does work
Nov 28, 2006 | British Telecom Freestyle 2200 Trio...
Compaq Evo N410C Notebook Logo
44 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
