I have water leaking from somewhere inside. It is not the hoses. I cannot see the source. It simply runs out from under the washer. It is only a cup or two per load, but disconcerting nonetheless.The washer is nearly three years old, but has only been subject to normal, household use.
My 2.5 year old Bosch Nexxtg 500 WFMC3301/UC washing machine fills then drains. Does not complete...
(More)
My 2.5 year old Bosch Nexxtg 500 WFMC3301/UC washing machine fills then drains. Does not complete wash cycle. If I leave off for a couple of days it will fill then drum turns for awhile, but will not complete cycle.Have checked pump and all hoses, all clear.No error codes when it stops, it just shuts off. Ran diagnostics and got a d9 and d18? Is it my motor control board?And if so, why would it go after only 2.5 years???
Water will not drain from the machine. We washed a bathmat with a rubber backing and it came apart....
(More)
Water will not drain from the machine. We washed a bathmat with a rubber backing and it came apart. Something is clogged, but the owner's manual just says to restart the DRAIN program. We've done that as well as SPIN, but nothing works.
After putting on a normal wash cycle, approximately 10 minutes into the wash, a beep comes on (quick...
(More)
After putting on a normal wash cycle, approximately 10 minutes into the wash, a beep comes on (quick beeps of about ten) then stops with an error E3 on the display.
