Question about Jenn-Air JS48SEFXDA Stainless Steel Side by Side Refrigerator
Getting at a clogged drain in evaporator compartment
Drain pan is clogged but unit is built in, how do u access the evaporator section
    Scholar:
  • 146 Answers
There is a panel over the evap. in back of the freezer section. Remove it and you will see the drain at the bottom of the freezer below the evap.. You will see a little tray with a hole in the center of it. You will need to clean out this tray and run a wire down through it to clean out the tube that runs to your drain pan. Don't use a coat hanger or anything too stiff as it may puncture or pop the hose off. It has to be something flexible but strong. That should do it!
Good Luck!
God Bless
Posted on Dec 26, 2007
    Sergeant:
  • 288 Answers
The evaporator is in the freezer section. Find the fan, remove the panels panels around it. Good luck.
Whirlpool model ED5HHAXV002 is leaking big pools of water several times a day. Where can I find the drain hose to see if clogged and pan to see if cracked? What else should I look for.
Defrost drain would be in freezer compartment underneath evaporator coils. You will have to take inside back freezer wall off to access it. Pan is under unit.
Sep 08, 2017 | Whirlpool Refrigerators
Whirlpool refrigerator ER2CHMXPL00 & leak
If you have water leaking into the fresh food section of the refrigerator, then the condensate drain if either frozen at the evaporator OR clogged at the drain pan or both. There are air vents in the top of the fresh food section to allow cold air down from the evaporator compartment and return air up from the fresh food section, and these holes cannot be covered or closed off. Check the drain trough under the evaporator for ice build up. Also check that there is nothing stopping the water flow down at the drain pan. If there is no water in the pan under the refrigerator down by the compressor, you have a restriction that needs to be cleared.
Jun 25, 2016 | Whirlpool Refrigerators
Maytag MZZD2766GE side by side refrigerator: Water collects and freezes on the floor inside the freezer. Then apparently some of the ice defrosts as I get water on the kitchen floor under the...
Hi and welcome to FixYa, I am Kelly.
This is caused by a clogged evaporator drain that is item 5 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47966
It can be clogged either in the funnel area or at the end of the tube underneath the refrigerator.
Item 5 catches water from item 14 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47966&diagram_id=28494316#d28494316
Your evaporator drain is clogged. (how to clear it)
  • Unplug the unit remove the freezer contents and do a manual defrost by directing an external fan at the freezer compartment for just over 2 hours. (Makes a water mess so be prepaired) This is a must do!
  • Remove the rear fiber-board compressor and condensor coil cover and locate the compartment drain tube in the drip pan. Make sure the end of the tube is NOT blocked. Clean as necessary.
  • After the 2 hour period... use vacuum forced air OUT pressure on the end of the drain hose in the drip pan. Have a 2nd person listen for airflow in the freezer compartment. This will float out any debris from the compartment drain funnel.
  • Clean the condensor coils and fan while the unit is unplugged but do NOT use anything sharp.
If you can not get air-flow up through the compartment drain funnel underneath the evaporator coils you will have to remove the access panel and remove the debris from the drain funnel.
Return the unit to normal service after cleaning. Watch for more ice build up after a week. No ice blocks after a week... no worries. Ice under the ice-maker... replace the inlet water valve due to it bypassing water when in the OFF mode.
Thanks for choosing FixYa,
Kelly
Mar 01, 2011 | Maytag MZD2766GES Side by Side...
Ice in the bottom of the freezer
Ok here is a generic response without a model number.
One of 2 things have happened. Either the inlet water valve to the icemaker has failed as noted by ice blocks in the ice bin or
If you need model specific information.... I need your exact make and model number in any response.
Kelly
Feb 19, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
Water has started leaking from the diffuser of a GE TBX14SYSJRWH. How to fix?
the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website). If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction. Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
Mar 29, 2010 | Refrigerators
Maytag fridge water dripping from inside freezer side
This sounds like the evaporator drain may be clogged either in the freexer compartment or at the outlet to the drain pan under the unit. Every defrost cycle the defrost element makes water by melting the ice on the evaporator coils. If the drain is clogged there is no other place for the ice to go. Many times the drain may just have ice buildup in the evaporator drain funnel that can be corrected with a manual defrosting.
To do this manual defrosting all you do is first unplug the unit then remove everything from the freezer compartment. After that place a fan blowing into the freezer section for a little over 2 hours. Please NOTE this will make more of that pesky water mess so be ready to tend to the mess as it presents itself.
After the 2 hour fan session plug the unit back in and reload the freezer compartment with previous content. Monitor for the possibility of the water manifeting itself again.
In addidtion to the above there is a drain pan catch basin in the bottom of the unit near the compressor. They are usually white plastic on Maytag units and not to rugged. Make sure that the drain pan is not loaded with debris. There is about a 1/2 inch diameter opaque plastic line that drains into the catch basin. That is the Evaporator darin tube. Ensure the very end of the tube does not have caked up debris in the very end of the tube. Sometimes this tube cakes up and then the debris dries hard inside the tube near the end. Make sure the tube is free of foreign objects and clean.
After all of the above / cleaning and clearing / manual defrosting it is still making water then most likely the lower panel under the defrosting element / evaporator may have become disconnected allowing defrost cycle water from the melted ice into the freezer compartment vs exit via the drain. To fix the disconnected power metal panel problem the rear freezer panel would have to removed to re-attach / repair the metal panel that guides the water into the evaporator drain.
Thanks for using FixYa.
Kelly
Mar 26, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Water leak self defrosting
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website). If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction. Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
Mar 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Intermittant water leak front left hand side and ice build up on inside base of freezer compartment, but no evidence of water leaking out from door it seems to come from underneath the appliance.
Sounds like the drain hose from fridge unit to evaporator pan built on top of compressor is plugged. The drain holes are small and clog easily. I like to make the holes bigger. A pipe cleaner helps to clean the inside of the drain hose.
Make sure water is dripping onto evap tray.
Nov 25, 2009 | Refrigerators
GE Monogram Built-in refrig has blocked evaporator drain.
You should be able to see the drain under the coil. Part 804 on this diagram. Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing.
Aug 25, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Ice Buildup
Hi
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 26, 2009 | Refrigerators
Jenn-Air JS48SEFXDA Stainless Steel Side by Side Refrigerator Logo
175 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
