Washing Machines Logo
Posted on Oct 12, 2009
Bosch 1200 classixx not spinning
Machinewill not spin, belt is in good order however I kep getting a continuous clicking from the machine as though a sensor is not making
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 12, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2099
Points
Bosch 1200 classixx not working properly. On 12 min spin cycle it starts then after 1 min timer reads 0:01 and it stops. washing cycles run but doesn't seem to be any spin action
2helpful
2answers
Washine machine not spinning
It sounds like a snapped belt or a broken motor. Can you here the motor run? You can access the motor and the belt from the back of the machine. If it is the belt snapped, this is easy to replace yourself. If it is the motor, you will need a repair man.
Bosch classixx 1200 It take in water then stop. I can drain it but it will not spin.
It looks like there could be a problem with a belt, maybe it sliped off, or maybe it broke, i would look that first
3helpful
Bosch classixx 1200 wont spin at all, water fills ok even pump to drain it back out .can hear it clicking as it tries to get motor to turn
You need to check the back of the unit and there's a strong possibility that the belt is broken or slipped out of track.
1helpful
Flash from the back of the washing machine.
it sounds like the brushes have gone in the motor that turns the drum
31helpful
2answers
Error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
17helpful
Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
1helpful
2answers
The drum won,t go around or spin BOSCH Classixx 1200 washing machine
BOSH WFL 2260 SPINS OK BUT WASHING CYCLES DO NOT WORK. FILLS WATER OK
My bosch classixx 1200 express
Close the door and turn the dial to drain
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
