Question about Vacuums
Electrolux upright vac
Genesis model roller doesn't roll, belt is ok , is roller supposed to roll if carpet is high?? my carpet is low knap?
  • Anonymous Mar 26, 2014
    where is belt
  • 1,673 Answers
Belts can look ok, but after a short period stretch so they won't turn the brush roll under load, if you have never changed it, and if it is a flat belt, I would try a new one.
Posted on Feb 17, 2008
How to fix series 3500 upright vac
With vacuum laying flat with back facing up, remove the 5-6 screws from the bottom of the nozzle, turn on it's side, and pry into 2 slots on either end of the bottom of the nozzle to release the top cover. Lay vac flat on the floor/bench face up, remove the 2 small screws on either end holding the roller brush in place. Pop the belt end of the brush roll out of place, place new belt in, and simply reverse all previous instructions. With 30 yrs. experience dealing almost exclusively with the original Electrolux, I have a legitimate store front business and do service by mail at a reasonable cost if interested.
Hope that helps! Mick
Sep 24, 2014 | Electrolux Vacuums
How to repair windtunnel hoover agitator that will not turn
Likely a broken belt. Also check the agitator brush roll bearings (in either end under the end caps) for hair, strong, thread, etc. as this will make the brush roll harder to turn and wear/break belts prematurely. If all these check okay, then observe the tensioning roller that causes the V belt (runs from the idler pulley to the brush roller) to be sure it is swinging down when the handle is released to hold tension on the belt, causing it to rotate. These tensioning rollers can break, but often are locked into the "Bare Floor" setting without the user noticing. Slide the carpet brush roll selector (located on top, next to the floor height slide adjustment) back and forth and make certain it is all the way into the "Carpet" setting to allow the tensioning roller to engage. [Note: The tensioning roller is always retracted (in the neutral or off position) when the handle is in the upright position. You must release the handle to allow this tensioing assembly to engage.]
Sep 05, 2014 | Hoover Model U6485900 Upright Vacuum...
Replace belt genesis upright
Turn vacuum upside down on flat surface, remove the 6-7 screws from the bottom of the power nozzle, lay it on it's side and pry on the two accessible internal tabs to pop top cap of the nozzle off to access the pn motor assembly. Lay flat on it's back again and remove the screws that hold the roller brush in, remove the roller brush, remove old belt, install new belt on brush roll and pn motor geared spindle, push brush roll back in place, replace screws and pn top and VOILA!'re back in bidness! Hop that helps!
Jun 25, 2014 | Electrolux Vacuums
The roller wont roll
take it apart and clean the crud out of it, re-assemble and NEW drive belt while you are at it!
Sep 14, 2013 | Electrolux EL8807A Precision BrushRoll...
I have a 15 yr old electrolux genesis upright vacuum cleaner that I can't get the roller out, to replace the belt.
There are two small screws at the end of the brush roll on some of these. There is a bearing block recessed into the housing at a slight angle to help tension the belt, so it comes out at an angle as well. It often fills with grit and you must clean the grit out carefully without damaging the blocks or housing. Sometimes WD 40 helps is the area has any rust build up. Then work a large screwdriver under one end the brush for leverage being CAREFUL not to damage the brush housing. Do not soak with WD40 as it will also get into the brush roll bearings
Jun 09, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Brush Roll belt won't engage on WindTunnel self-propelled
When you had the brush roll off, did the ends turn freely? If not then the brush won't turn and the belt will just slip. You would have to replace the brush roll if either of the ends are frozen. Other then that you would have to remove the top cover to see if there any broken parts, there is a spring loaded asm, it has a black wheel that will push the V belt when it is in the carpet setting and the handle is in the down position, it could be jammed so the roller is stuck.
Jul 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
95 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
