Question about Sony KV-32HS20 32" TV
KV-32HS20 Picture goes out and screen is black/white snow... sound still works. Found a blog about a Ks-32S20 with similar problems, tried to follow solution given but could not find the "little metal box" with the "picture" and "focus" adjustment screws on it.
  • lumpy5000 Dec 29, 2008
    I have this same problem. Happens in all modes: Antenna, cable, games, DVD, etc.
  • 149 Answers
Hi there, you do have a tunner problem, the little metal box is the tunner which is connected to your arial anttena or cable line. try to toch the ic near the tunner and feel if is it hot, you may be have a defective ic parts. check some parts at tunner section. ty
Posted on Dec 26, 2007
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Oct 14, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Sony Wega Trinitron KV-32HS20 does not tun on and the standby light flashes 4 times. I can hear the sound but no picture and the it turns off automatically after a few seconds.
This is a tip I got from a tech bulletin.
IC600 output pins 14, 15, 16, all have aprox 130v (all should be higher) until relay clicks
then they drop off. 200v line goes up to 50v, 135 goes up to 40v.
Checked D611 (135v rectifier) it was fine. Checked D615 (It's labeled D601 on the board)
it was shorted. (D615 is the 19v rectifier for the Audio B+) Removed D615 set power up
and has good picture with no sound.
Sep 08, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Losing picture when screen shows a white background
Try switching to a different cable provider. I have had many problems with their a/v boxes in the past and have found they aren't very compatible with most newer tv's. Time Warner/Comcast boxes have worked great for me.
Also, don't listen to the electronics stores, they are just out to make money, although it may fix your problem, it is unnecessary.
Check your tv's manual for settings that may fix that problem, like "source refresh time" or anything to do with signal loss and refresh rates.
For more info, contact me.
Thanks for asking!
-Josh
Feb 26, 2010 | Mitsubishi WD-Y65 65" HDTV
Sony Wega Trinitron KV-32HS20 TV
The 4 blinks usually indicate a vertical problem. If you can solder, you can fix this yourself. Let me know if you wish to attempt this repair. If not, expect a parts cost of $10-$15 plus the local labor rate for the repair.
Dan
Oct 01, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
Picture Blinking
9 times out of ten restoration is temporary,at best.....
Requires socket adapter for your tube or use universal
adapter...tricky hook-up = read instruction book for CR-70
...........................T.
Dec 18, 2007 | Sony KV-32S20 32" TV
No Green in picture
KV-32S... and KV-32V.... notorious bad picture tube.....
not worth pursueing..........................T.
Sep 04, 2007 | Sony KV-32S20 32" TV
Sony KV-32HS20 32" TV Logo
73 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
