Question about Pioneer DVL-700
My LD DVL-700 don't play any DVD
After fixing the header mechanism of my LD I tried to play a DVD disc on it. But when I put the disc in the plate and push the buttom "Play", the player goes to "sleep" position: the header goes back, until the end of the guide and stays there for ever. It make nothing!. Only moving the header with my fingers to the central position and turns on the player, the player starts to functioning again. I tried a lot of DVDs disc and with all of them happen the same. Does anybody knows what happen? Maybe my LD needs a firmware update? or is another problem?
2 Suggested Answers
  • 124 Answers
SOURCE: Pioneer DVL-700. Unit Plays LD
The dvd's are not spinning up correctly. If the belt inside is worn this will cause cd's to play but dvd's fail. open up and replce belt (small black rubber running on motor)
Posted on May 13, 2011
I insert disc, but after a little while, disc ejects without even playing. Help!
happen to all disc?
if so, check the 'home' sensor for the tray. need to open up and take a look.
Jun 14, 2014 | Pioneer DVL-V888 DVD Player
Flash Sum
  1. Have you tried cold starting it; disconnect it completely from the mains for ~10 mins, then reconnect and try again.
  2. It is probably a problem with the EPROM or the CPU. You could try resetting the software by holding in the STOP button while turning on the power to the unit. If that doesn't work it sounds like the EPROM is corrupt or the CPU is bad.
Nov 11, 2007 | Pioneer DVL-V888 DVD Player
Pioneer DVL-700. Unit Plays LD Discs & CD's fine but will not play any DVD Videos.
May 11, 2011 | Pioneer DVL-700
Pioneer DVL v888 disk tray will not open. There is a disk in it.
There isn't a way to open it by hand without removing the cover.
As for fixing the tray, there might be a few reasons why its not working. When you press one of the eject buttons, do you hear the usual whirring of motors? If you do and the tray still does not open, then the problem may be a broken rubber belt near the front.
If you don't hear the whirring of motors, then try playing the disk. If the disk does not play either, then the disk loading mechanism is out of sync and may require manually resetting it. This is accomplished by carefully pulling the spring loaded carriage upwards or downwards until it responds to the play button. Be very careful not to touch any of the exposed electrical components and capacitors, electrical shock may occur.
Apr 05, 2009 | Pioneer DVL-V888 DVD Player
Compaq presario 700us will play cds wont play dvds
Try to put your laptop always on flat surface. Uneven base gives angle to the already tiny clearance space for the disc. Could be that the DVD disc run coz its finer, it will spin much slower than CD disc.
Hope i give you some good observation.
Mar 29, 2009 | HP Compaq Presario 700, 700A, 700AP,...
LD Repeats itself every 15 seconds in play, DVD's play fine.
This solution should help or at least decrease the occurances.
It has worked for me.
The problem seems to be that the original manufacturer lubrication on the glide rails and on the glide track has lost it's viscosity causing the Laser Pick-up Head gliding process to bind causing video to repeat at any random binding point.
Open the top cover and play a Laser Disc.
Manually change from Side "A" to Side "B".
Observe how the Laser Pick-up Head glides on the track and on the glide rail.
Stop play mode and remove the Laser Disc.
With the tray open, unplug the power at the power electrical cord. Now with the power removed and the tray left open, take a "Q-Tip"™ and spray some ""WD-40"­™ on the "Q-Tip"™.
Now gently tap the saturated "Q-Tip"™ along the full length of both the upper and bottom glide rails as well as the glide tracks.
Repeat this process.
Be careful not to touch or lube the Laser Pick-up Head with the "Q-Tip"™.
If you do touch the Laser Pick-up Head, just gently clean it with another "Q-Tip"™ saturated with alcohol.
When finished, reconnect the power and play a Laser Disc.
Manually change From "SIDE "A" to SIDE "B" about three times to spread the "WD-40"™ evenly and ease the gliding process.
This solution should help.
Feb 08, 2009 | Pioneer DVL-919 DVD Player
had the same LD FVU (Load FVU or firmware disc) message and fixed it this way: download firmware from and make firmware disc and insert. After it loads and updates, you need to activate your remote again. When the message SET 1 appears, on the remote press ENTER and 1 together for 10 seconds. Done.
Jun 24, 2008 | Panasonic DMRES15 DVD Recorder
Disc Tray Won't Open
Sounds like a belt is slipping.
wont open, wont close, makes clicking/grinding noises etc.
Jan 25, 2008 | Pioneer DVL-909 DVD Player
Tray won't open
It could be electrical or mechanical. Without checking there is no way to be sure. You can get the service manual for your model for 10.00 at the following link. That should get the problem taken care off.
Tray Not Open
possibly what hass happened is that your disk has got wedged, (or that someone tried to insert more than 1 disk)
try GENTLY shaking the unit (unplugged) to see if the disk mechanism frees itself.
as it is NEW you really shouldn't do any more than this as it would invalidate the warranty, take it back to the shop you got it from and they should handle it for you,    Tell them not to forget that you have a disk in the drive.
Oct 12, 2007 | Pioneer DVL-700
Pioneer DVL-700 Logo
81 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
