Question about Kicker KX600.1 Car Audio Amplifier
Protection light is on
I have a Kicker KX600.4 and it just when out and now it wont turn on it haves a light that says protection and that one does turn on
  • 631 Answers
Disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Posted on Dec 26, 2007
3 Suggested Answers
  • 631 Answers
SOURCE: amplifier wont turn on.
Generally, when an amplifier goes into protection when you attempt to power it up, it means that the output transistors have failed.
Measure the DC voltage across the B+ and ground terminals as well as across remote and ground. If you have less than 11 volts when the amp tries to power up, the amp could be shutting down due to low voltage.
If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Posted on Oct 25, 2007
StuartB
  • 807 Answers
SOURCE: blinking protection light on mrv-t757 amp
Could be the power supply or output stage electrolytic capacitors.
Possibly breaking down/drying out inside.
Posted on Mar 17, 2008
Kicker kx850.4 protection light stays on know power light
Check power make sure you have solid 12 volts. Disconnect speakers, shorted speaker can cause protection mode to engage. If still in protect mode will need to repair. Kicker does out of warranty repairs on kx series amps or try T.I.P.S contact at linearpower.com. Iirc Ray @ tips was one of the engineers at kicker back when kx series was introduced.
Jul 19, 2016 | Kicker Car Audio & Video
I have a kicker 500.2 red protection light is on and red light on top of amp flashes every couple seconds. Have checked all connections and other amp in truck works good. I bought two of these amps and...
Disconnect all the wires except the three main power wires, ground, 12v battery and remote. Now, turn on your radio, if the protect light is still on then there's an internal short in the amp. If the light turns green, then there's a short in either the auxiliary cables or the speaker outs. If it turns green, then troubleshoot the other wires that plug into the amp by connecting them one at a time until the protect light comes on, which will tell you that there's a problem with that speaker/aux wire.
Jul 25, 2011 | Kicker KX500.2 Car Audio Amplifier
Protection light keeps flashing on and off
try hooking up only the power ground and remote see what happens if protection light is on then u have a problem with amp if it goes off then hook up rca if still off then hook up speaker wire if it turns on then u have a prob with speakers
Feb 02, 2010 | Kicker ZX10001 Car Audio Amplifier
I think ma kicker kx1200.1 amp is blown or ma kicker L7 are gone
that would be the amp. sorry to say. when a wire crosses over, it sends a shock through the amp, there are a few things to try just to see if you fried the amp. the first thing to try is to move your ground to a different location. second thing to look at would be the fuses. alot of times the fuses will blow at the slightest shock. the amp will still turn on if you have an amp with 2 fuses, it just wont be getting all the power it needs, which could be causing your problem. also, it is worth the hour and a half to mount everything down in your vehicle. you might check the kicker website, because i have herd rumors that kicker offers a lifetime warranty on almost all of their products. best of luck, and i hope you didnt fry your amp.
Apr 09, 2009 | Kicker KX1200.1 Car Audio Amplifier
Goes into protection mode for no reason
if the amp is powering on the sub and playing and then turns in to protect mode it could be the amp is getting hot and its kicking into protect so you wont fry the amp
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Blinking protection light on mrv-t757 amp
Mar 17, 2008 | Alpine MRV-T757 Car Audio Amplifier
Wont turn on
There is a short some were check all hot wirs for any bare spots . If that is not it most likley when you installed it you blue italways hook main hot wire last.
Oct 25, 2007 | Kicker ZX10001 Car Audio Amplifier
Amplifier wont turn on.
Kicker KX600.1 Car Audio Amplifier Logo
105 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
