Question about Cuisinart TOB-30 Toaster Oven with Convection Cooking
Cuisinart toaster oven modele no.TOB-30BWC, serial no.50421.
The toaster oven broiler is about 2 years old and since about 2 months each morning when we want to use it in the Toast postion and press the start buton it automatically goes to stop and does not work. We do not know how to fix this up?
  • 1 more comment
  • Anonymous Dec 30, 2007
    i have a similar problem, same model. after two years when i press the toast button now it makes a strange noise, the red light fades, and the heat never comes on. it also makes strange buzzing noises if left plugged in... let me know if you've been able to get it fixed.
  • blt88 Jan 23, 2008
    I am experiencing the same problem posted by "guest" on Dec 30th. I am anxious to see if replacing the relay fixes the problem. Let us know "caseytronic" blt
  • Anonymous Mar 19, 2014
    lcd timer/clock doesn't lite up, works fine other than that
    Problem Solver:
  • 5 Answers
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
Posted on Apr 07, 2008
  • qwerqwer May 30, 2008
    You can try to clean the contacts with alcohol (and/or very fine sand paper) as stated in other discussions, but the fix is a near term solution and eventually the contacts will arc and pit again. This leads to higher temperatures across the contacts and if the contacts fail before the plastic cam melts, your free to address the contacts for cleaning again. Just remember this failure will occur more frequently each time. Once the cam fails (melts) your out of luck. Write Cuisinart and tell them how unhappy you are with your toaster oven. If you get the same response I did (we only will replace it under warranty) then feel free to recycle it (or throw it away) and spend your money on a delonghi (no affiliation - my hand me down 7 yr old one keeps working great) or another brand. Companies these days should have better quality control on the products (from china) they slap their name on.
    For the record, mine TOB030 has about 10 hrs run time on it before it failed @ 1.5yrs old. The inside is still brand spanking new!
    Just my 2 cents.
  • jawajames
    jawajames Jul 27, 2012
    My TOB-30 failed after 5+ years. I opened it up and found that the cam had melted on the first contact. Ugh.
While the contacts on the cam do get dirty from the arcing that is not the main reason these units have all been failing with the same problem. The "toast" problem is caused by bad capacitors on the 2 small circuit boards inside. The reason the toast function fails and the rest of the oven works is because the toast function has a seperate set of electronic circuits for the timer and heating elements. If you change out the 4 electrolytic capacitors this will fix the problems. There are three 220uf 16V and one 1uf 50V. I would change out the 220uf with at least a 25V since this is activating the 12v relay circuit.
Before changing these out the Toast function would buzz when selected, it should not...this means the heating elements are on, though just barely. Next, the unit would just go out or stop working when you press the Start button....and lastly the timer stopped beeping. After replacement all functions returned to normal. My guess is that the heat from the unit (and a current limit resistor on the circuit board) simply dries these caps out and they fail.
Posted on Mar 02, 2011
The best solution based upon the dates of the post are that it has a 3 year warranty.
Posted on Dec 01, 2008
I have the same problem. It is due to a bad relay switch in the toaster. I have found that for now, my toaster will work if I leave it on the "TOAST" function rather than "OFF" overnight. I think it lets some current or voltage hit the relay and encourages it to work.
I will try to replace the relay and post a "how to" on that when it is done.
May all of your toasting be succesful.
Posted on Jan 21, 2008
  • caseytronic Jan 24, 2008
    I replaced the relay switch, but the problem was not fixed. Du-oh! Looks like it wasn't the relay after all. At this point, I'm not sure what is wrong, but my work around seems to work still.
I have a cuisinart toaster oven. Model TOB 30BWC. The selector/timer dial doesn't work so the oven is always on when it is plugged in. I would like to get a new dial
Looks like replacement knobs are not available from Cuisinart.
However, any 1/4" shaft knob with setscrew should work.
If you have a Radio Shack still in business near you, they are blowing them out for under a buck a knob:
RadioShack Hexagonal Control Knob
Other styles and sizes are also available.
If you do not feel like looking around, here are a pair of universal knobs that should work, although they do not look the same:
Part TOP1345 for Cuisinart TOB 30BW Appliance Factory Parts
Mar 26, 2017 | Cuisinart Toaster Ovens
How do I clean the drip tray and broiler pan?
The drip tray pulls out the back of the oven. It can be soaked in hot soapy water.
Jun 19, 2009 | Cuisinart TOB-165 1500 Watts Toaster Oven...
Cuisinart TOB-30 toaster oven
I have the identical problem. Where can I find a replacement foot?
Mar 14, 2009 | Cuisinart TOB-30 Toaster Oven with...
Cuisnart Toaster Oven Broiler TOB-165 Element
there not replaceable . metal straps are welded to the ends to make the electral connections . thats why there are no elements for this oven , sorry factory-store-home-dump AS FAST AS WE CAN
Jan 20, 2009 | Cuisinart TOB-165 1500 Watts Toaster Oven...
CUISINART TOB 175 CONVECTION OVEN MANUAL
Cuisinart has the manual on their website:
http://www.cuisinart.com/manuals/index.php?cat_id=15
Scroll down to the link for the TOB-175.
Nov 19, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Warning tone?
Have you tried turning the function button to off? This has worked for mine.
Aug 18, 2008 | Cuisinart TOB-30 Toaster Oven with...
Lower heating eliments don't heat or glow. Only top ones work
The elements are not orderable, but you can call Cuisinart with your serial number - the product has a 3-year warranty, and that is definitely a defect - will they glow if you put them on Toaster setting?
-Tha Mp3 Doctor
Aug 03, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Toaster oven power failure
Call Cuisinart - that product has a 3-year warranty.
May 06, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Broiler element
Its an on or off thing. No way to control the flow of electricity.
The elements are bigger than necessary to heat the unit quickly, the problem you have is a bad thing with food that burns easily but a good thing that makes these units come up to temp so quickly after turning on.
Unfortunately the only thing you can do is put more space between the element and your food or use aluminum foil (not suggested, its too close to the burners).
Eventually the contacks will fail (unless you are one of the lucky ones).
Good Luck
Feb 03, 2008 | Cuisinart TOB-30 Toaster Oven with...
Cuisinart TOB-30 Toaster Oven with Convection Cooking Logo
1,615 people viewed this question
Top Cuisinart Toaster Ovens Experts
D. E. Hev
Lawrence Oravetz
J.D. Browning
J.D. Browning
Are you a Cuisinart Toaster Oven Expert? Answer questions, earn points and help others
