Question about Kingston EtheRx SOHO Networking Hub
Kingston EtherX Soho Hub -5 port
We have one of these hubs, but we don't know which power supply transformer to plug into it - how many volts
is it supposed to be, does anyone know? You have a
picture of this exact same unit on this site, so I'm hoping...
Thanks,
Glenda
It should be 7.5 volts DC. you can find the manual supplied with it at this web address http://www.kingston.com/japan/support/manuals/KNE8tph.pdf
Posted on Dec 29, 2007
Model no ad-0760d
input 240vac 50hz
output 7.5vdc 600ma
center +
Posted on Feb 24, 2008
I have hub4 friend giving me hub 5 so I just change it over and that all I do
Should be just a changeover the hub is not very intelligent so there should not be too much issue. Speed of hub ports ? 10/100/1000 Mb/s
hubs basically repeat the network packets to all ports .
what feeds into the hub what speed is it at and what speeds does the hub support is the only issue you may have. Assuming you have ethernet hubs.
MUST use 5 hubs power supply AC to DC adapter with the 5 hub device.
do not just pull power plug out of 4 hub and put it in 5 hub device unless you know they are compatible with same DC voltage and current rating it is much simpler not to mix them up.
Sep 13, 2016 | Computers & Internet
The cable that came with my hub has a pigtail for connecting to the computer. TWO USB plugs. I have long since lost the packaging so I don't know what they are for. One is blue while the other is the...
It could be to supply extra power to the hub. Basically the USB can only supply 500mA of power so by using 2 ports one can supply 1000mA double what one port could power.
Feb 26, 2011 | Sakar (M01517) 5-Port USB Hub
Some of my peripherals, trackball inc. want to be connected to the netbook instead of settling for my hub. What do I HAVE to connect to the computer among CD drive, hard drive, printer, keyboard,...
Most likely your USB hub is not capable of supplying enough power to support all your peripheral devices. USB devices are powered by 5 volts from the USB port. If you connect a hub to a USB port and connect a lot of devices to the hub, there is not enough 5 volt power to let all devices work. To fix this, most USB hubs have an external power option that when plugged in will supply extra power for any connected devices.
If your hub does not have an external power option I would suggest you purchase a new hub that does have an external power supply.
Good luck :)
Jan 25, 2011 | ASUS Eee 4G Notebook
What's the voltage output from transformer
hi YOU CAN FIND THE SOLUTION FOR YOUR HUB
Warranty Period : Lifetime Warranty Integrated/Included Cable Length : 1.8m Belkin Pro Series USB Device Cable LED Indicators : 1 x Power LED (Green), 4 x Port Indicator LEDs (Green) Max. Load Per Port : 500mA Package Contents : USB 4-Port Hub, USB Device Cable (A-B), User Guide, Power Supply Power Supply Specifications : 5 V DC 4 A (Provided) Option to Expand/Cascade : Yes, via Hubs of this design (stackable) or other Enclosure Type : High-Impact Plastic Enclosure
Sep 27, 2010 | Belkin ExpressBus Networking Hub
Hello, I have a Belkin 2.0 USB 7-Port Hub, and having trouble with it. When i plug it into my computer, nothing happens, there is no power light and ultimately it seems as though the device is dead. ...
You first need a CAT 5 cable to go to where your internet connection is, such as a modem or another router to your hub. Then you plug another CAT 5 from the hub to your PC. You need to feed internet to the hub then your pc will recieve a connection from the hub. And of course the hub does need power. Hope that's what you were asking.
Mar 09, 2010 | Belkin (F5U237) 7-Port USB Hub
Power supply for Targus 4 hub usb 2
Most USB hubs do not need an external power supply, except when a connected USB device draws more power than the computer/laptop USB port can supply. In this case an external power supply will need to be connected to the USB hub.
Normally this would be a 5 volt power supply, but make sure the polarity on the connector matches the power connector on the hub, check the label on the hub, sometimes it states to power requirements of the hub as well as the polarity on the connector. Normally the pin on the hub's power connector is positive (ie. +5V)
Nov 13, 2008 | Targus PAUH217U 4-Port USB Hub
Connection problem between modem router and hub
Sounds like you may need what is called a "Crossover Cable' connecting your router to your hub, or if either device has an uplink port, use it on one device to connect to normal port on other device. Here are instructions for making your own cables: http://www.lanshack.com/make-cat5E.aspx
Dec 08, 2006 | Kingston EtheRx Networking Switch
Kingston EtheRx SOHO Networking Hub Logo
1,080 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
