Question about Philips 55PP9401 55" Rear Projection Television
Scrabble when HDMI cables are hooked up to AV4
My CD player and Playstation 3 can connect to this tv using the HDMI cable through the AV4. My problem is, when I connect the cables to the back of the tv all I get is a distorted serires of lines and scrabble. I recently had a tv repair guy come out and replace the "brain" of the tv (what he called it) the part number for that is 313503710981. Im thinking he installed an older model that isnt HD compatible. any help would be great.
  • 8,596 Answers
Your issue has nothing to do with the repair. This TV model maxes at 1080i, and your video game maxes at 1080p. Set both the TV and the video game system to either 1080i for high-def or settle with 480p by setting bothe the TV and video game to that resolution. If the problem persists even after this, then check the Philips website for a firm upgrade. WARNING: use of modern video game systems with a plasma or projection TV is a bad idea.
Posted on Feb 19, 2008
Can I play playstation 3 on 1993 Samsung tv
How to Connect a PS3 to a Very Old TV - YouTube
? 4:49
https://www.youtube.com/watch?v=k7lbl6irj4E
Sep 24, 2011 - Uploaded by Scotty Chezz
Hey, guys! Here's a video on how to connect a PS3 to a very oldTV. I hope this will be useful for those ...
Re: PS3 compatibility with Samsung TV - PlayStation® Forums
community.us.playstation.com/.../PlayStation-3.../PS3...Sams...
PlayStationA description for this result is not available because of this site's robots.txt - learn more.
Can I hook up a ps3 to my hp laptop using hdmi cable ...
www.tomsguide.com/forum/50989-35-hook-laptop-hdmi-cable
Mar 31, 2013 - 14 posts - ‎11 authors
I'm having trouble taking my ps3 with me on trips because the tv isn't compatible in a hotel. Can I hook up my ps3 to my laptop through my hdmi ...
How to use your smartphone through a TV - PC Authority
www.pcauthority.com.au > Gadgets > Home Theatre > Feature
Jan 28, 2016 | Video Game Consoles & Games
I have this receiver hooked up to a Vizio LED tv and a Vizio Blue Ray using HDMI cables. The surround sound works from the speakers while watching a dvd (HDMI -1 connection) but I have no surround sound...
AV cables don't pass surround sound through, they are pretty much just left and right stereo. You need to turn pro logic on on the reciever to "pretend" to play surround. The better option of course would be to use a digital signal like another HDMI cable or digital optical audio from the cable box, if thats what your using.
Jun 16, 2011 | Yamaha RXV467 Receiver
My (Cable Service) wire feed is directly behind my HDTV and hooked up over my fireplace . The Rxv667 is located on a side wall book shelf. I have A HDMI wire running to the TV from my receiver. Do I need...
Is there a set top cable box, or are you feeding the cable directly to your HDTV (coax directly to the TV). If you are feeding cable directly to the HDTV then you don't need HDMI. There maybe exceptions, but most TV's don't have HDMI output. The only thing you need to run from your TV to the Yamaha is an audio cable. I assume your HDTV has an optical audio out (either TOS or coax.... Your Yamaha will accept either). Connect the optical audio cable to the AV4 input on the Yamaha. This way when you hit the TV scene button on the Yamaha remote, it will select the AV4 audio input (the default for the TV scene). The optical cable will feed the full audio signal, so that the Yamaha can pass through the surround sound or use the decoder as appropriate to feed your 7.1 or 5.1 speaker system.
If you have a set top box, you may be better off moving that near the Yamaha. In this case, cable goes to settop box, output of set top box via HDMI or component video (RGB) and optical audio to the Yamaha (if you use HDMI Input 2, and AV4 for the optical audio (if necessary), the TV Scene will select the appropriate inputs) and then an HDMI to your HDTV.
In case one, you may need to setup the TV to process the audio appropriately. I have experience with Panasonic Plasma but thats about it.
Feb 24, 2011 | Yamaha RXV667 Receiver
Hdmi Port wont work on PS3
you need to go into your console video settings and setup for hdtv to use hdmi.
May 21, 2010 | Sony Playstation 3 (PS3) Console
PS3 HDMI - Sony Bravi KDL-40V2000 Problem
  • Have your ps32_bing.gif in standby mode (red light).
  • Now, press andhold the power button in the front down. Your ps3 will beep twice. Letit go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
try this
May 08, 2010 | Sony Playstation 3 (PS3) Console
Can i hook my cd player up to the 56" tv? What size speekers can
Yes you can use a hdmi cable, or component cables connected to the audio input jacks. Don't forget to change the input with the remote to select the cd player for listening.
Mar 16, 2010 | Vivitek V37655 56" DLP TV
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Philips 55PP9401 55" Rear Projection Television Logo
79 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
