Question about Sharp AL 1631 Copier
Flashing L1 Display
I have a relative new Sharp AL-1631 and the L1 keeps flashing, The locking knob is in the open posisition and the head will only move about a half inch. then the L1 will flash.
Can any one help me?
Thanks rick
  • Anonymous Jan 08, 2008
    I have an AL-1631 that keeps flashing L1 on display problem how do I fix it.
  • Anonymous Feb 25, 2008
    displays L1 ,first blank sheets pasted though ,know L1 flashes and it will shout down
    Problem Solver:
  • 6 Answers
Clean the stripe band unther the glass
Posted on Dec 26, 2007
    President:
  • 2,072 Answers
L1:Indicates that the Main PWB sensed that the carriage did not leave home after power up or after start is pressed
You may have a bad scan motor, Fuses do blow on those.
Also check for the lamp carriage binding on something.
But as the fault states, the machine is not seeing the lamp moving forward .
Posted on Jan 09, 2008
AL-1631 is flashing "H". How do I fix this which appears to be heat related.
the h means that your fuser needs to be replaced. it might be fixable by changing the thermal fuse but most of the time the whole fuser needs to be replaced
Sep 28, 2014 | Sharp AL 100DR Laser Toner Drum Works for...
SHARP COPY MACHINE AL 1631 FLASHES A L1 ERROR
Most likely when removing a copy someone hit the scan lock on the front of the machine.
Look on the front , bottom side of the scanner where the paper comes out. You will see a latch that is used for shipping the machine that is more than likely locked.
Thats what causes an L1 90 percent of the time. Just slide it to the unlocked position or take a small screw driver and remove it and throw it away. You can put a piece of tape over the opening to keep dust and moisture out
Jul 15, 2010 | Sharp AL 1631 Copier
Error Message
You have a bad Laser Unit
Jun 02, 2010 | Sharp AL 1631 Copier
I have a sharp al-1631 flashing l1 code what is this and how do i fix it.
your scan unit cannot move. check if you use longer screw for top glass
May 24, 2010 | Sharp AL 1631 Copier
I have a sharp al-1642cs that will not work it just keep flashing L1 can you help
www.cyberscholar.com/sharp/resources/cop_man_soho_AL1642CS.pdf
http://www.service-docs.com/store/catalogue.php?cat=281&exp=0&resultpage=10 L1 00 Feeding is not completed L1 00 Feeding is not completed
within the specified time
after starting feeding.
(The scan head locking
switch is locked)
1.unlock Scanner unit
2. chang connecter
Scanner unit
May 09, 2010 | Sharp AL-1642CS Copier
Flashing L-1
When your copier scanner is locked.Then show L1
or sensor is dirty or scanner jam.
Solve: clean thoroughly then solve your problem.
Jan 22, 2010 | Sharp AL 1631 Copier
My scanner lock is flashing but it's unlocked??
L1 may be scanner lock or copy lamp faulty. Check the copy lamp.
Oct 28, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 is flashing 1 L. What does that
Hi:
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Andrew
Aug 09, 2009 | Sharp AL 1631 Copier
SHARP AL 1631 copier is flashing L1 and will not print
Ensure the carriage lock is off, if you have cycled the lock and restarted and still have the problem you may have a fault with the scan carriage.
Jul 06, 2009 | Sharp AL 1631 Copier
Flashing "L1" error
A letter "L"  and a number "1"  appear alternately = The scan head locking switch is locked. Unlock the scan head locking switch.
Hope this helps. Good luck.
Jul 29, 2008 | Sharp AL-1217 Copier
Sharp AL 1631 Copier Logo
406 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
