Question about Technics SL-1210 Turntable
Technic 1210 will not turn on
Technic was playing fine the night before then wouldnt turn on the next day. It is the not the fuses as i swaped it over with the working one.
  • 1 more comment
  • Anonymous Jan 26, 2008
    my turntable won't switch on as if there is no power going to it
  • Anonymous Dec 28, 2008
    The light won't come on - think it's the power pack,
    Rebecca
  • Anonymous Mar 08, 2009
    i have the same problem
    New Friend:
This is insane, ive had two decks for 10 yrs, they were working one night , both dead the next..... entire rest of system with at least ten peripherals are all fine, so it wasnt lightning.......???
Posted on Apr 14, 2013
Anyone know what's caused it? exactly the same problem here too..
just been googling for hours,... can't find anything that will shed a light on whats happened?..
anyone else do any better?
Posted on May 30, 2010
Me 2 cant belive it both have just died!
Posted on Jan 15, 2008
Get a new motor seems like its gone but they are impossible to get hold off and would cost u an arm and a leg to get new one
Posted on Jan 01, 2008
Im in the same boat same prob with mine not happy
Posted on Dec 30, 2007
Get tv out standby
you must test the fuse inside. And after that reset by disconnect the power cable from the outlet by 30 secons. and try again.
Go after to the MENU of the TV, and reset to the factory.
God bless you
Jun 19, 2013 | HP Computers & Internet
My 1210 was working fine the other day, my daughter was playing around with it turning it on and off but nothing too harsh. I went to turn it on today and there is no power what so ever. How do I change...
Your turntable may be plugged in to a "switched" power outlet on your receiver/amplifier. If it is, your amplifier needs to be on for your turntable to get power.
Apr 26, 2011 | Technics SL-1210 Turntable
Hello my name is becca i have a 2000 hyundai accent it was fine one night the next day i went out to start it it wouldnt got a boost it started but once the ground cable was taken off it died in seconds...
Batteries sometimes die completely for no apparent reason even though they were working fine only hours beforehand. Try another / new battery and get the alternator fuse checked, because it should not be obviously split, and replaced if necessary because with the fuse out, the battery will not be recharged. The alternator charging rate appears to be OK but have it checked anyway.
Oct 29, 2010 | Hyundai Accent Cars & Trucks
Me technic 1210s wont *** on ive tryed change in the fuses wiv 1 from tv an still nothing any ideas?
It could have got an internal fuse, not the one in the plug. Also the power switch might have broken. There's only one way to find out! Take the bottom off and have a look.
Jan 12, 2010 | Technics SL-1210 Turntable
My psp wont turn on
Replace the AC adapter. it may haved taken a surge over night. If this does fix the problem then the powerborad needs to be replaced. Your parts can be ordered from risingsonltd.com
If you need further help, reach me via phone at https://www.6ya.com/expert/eric_5b00a5ceab1c0cd2
Aug 19, 2009 | Sony PlayStation Portable (PSP) Console
What type/size of glass fuse has the coloured bands on
They are the standard type, it's just some fuse makers use coloured bands to indicate the type of rating, just like the colour codes on resistors. Your local Library should have a book which will give you the meaning of the colour codes for fuses.
Aug 12, 2009 | Technics SL-1200MK2 Turntable
Technic 1200 just stopped
throughing it away!
only joking,if all fuses are good internal an on plug then it could be a few things you need a multi meter an someone who knows how to use one an test the main board and componts an transformer.good luck
Jun 11, 2009 | Technics SL-1200MK2 Turntable
Technic 1210 deck
Make sure your 2nd turntable is connected to the PHONO input of your DJ Mixer or Receiver. If you have it connected to LINE IN or AUX IN, the turntable will be very low, as this model requires a phono pre-amp to amplify it's signal.
If this is set up correctly, then you might want to check your cartridge. Can you swap the cartridges out to see if the problem remains on the same turntable, or if it switches to the other turntable. If it switches, then you know the problem is with the cartridges.
If that checks out ok, you might have an issue with the RCA cables or Tonearm or both. At this stage, I would suggest taking it to a service center for assistance.
- OPTiC
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Apr 17, 2009 | Technics SL-1210 Turntable
Wont power on
buddy of mine had the same thing, i looked in side and it had a fuse out. the tricky part was finding it. his had 6, two you could see the rest- well lets say you have to look and not play super man. works but i have to now find a way to re- fous it. any one how?
Nov 25, 2007 | Samsung HCM5525W 55" Rear Projection...
Technics SL-1210 Turntable Logo
373 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
