Before you downloaded the drivers, did you have the DeskJet unplugged from the computer? (USB cable)
DeskJet was off, and unplugged from power source? (Surge protector)
If a hardware device, (such as that HP DeskJet peripheral), is attached via the USB cable, (Power provided, and unit turned on), AND THE drivers are not present, Windows hurries over, and matches Generic drivers.
Windows will try to match one of it's thousands of generic drivers. This = Doesn't Work!
You need THE drivers for that HP DeskJet installed, Before you attach the DeskJet to the computer, (Via USB cable), and Before the printer is turned On. (Drivers are in the Full Feature Software)
Select your OS; Select the Full feature Driver; Click on Download ; Save to your desktop; and then run the software; Then while installation select the "Recommended" option and install it;
Regards Soumajit
Even if you do not have CD Installer, that's alright. Hp do have an option where you could go to their website and download all the driver's without any cost. If you wish, you could also prepare a CD Installer by burning the Driver's in a disc ( Only for personal use ).
tried printing on A 4 card - began printing then stopped and sent card out with partial print at...
(More)
tried printing on A 4 card - began printing then stopped and sent card out with partial print at beginning of card tried 1 sheet in feed still no result - tried 6 sheets - no result tried 6 sheets still no luck
Der Drucker reagiert nicht auf den Befehl drucken. Es wird aber angezeigt das der Druckvorgang...
(More)
Der Drucker reagiert nicht auf den Befehl drucken. Es wird aber angezeigt das der Druckvorgang Leuft. Was kan ich tun?
