Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
Re-installation I've been trying to get to the setup page of my router after having reset it, but it doesn't seem to work anymore.
    Scholar:
  • 112 Answers
You will need to logon the router via the computer, if you cannot connect wirelessly, you may have to use a cat5 cable between the router and computer. The user manual that came with the router will show you how to do this. If you do not have the manual. Do the following: open internet explorer, in the address window type the IP of the router "example" http://192.168.2.1 your router IP should be on the bottom of the router. If not click start/run, type ipconfig at the > the router ip is listed at "default ateway". once you get to the routers logon page enter one of the following: username "leave blank" – username " admin " -or- username "admin" - password 1234 –or- leave password field blank.once logged on the router . BPCS
Posted on Dec 30, 2007
Nstallation cd is missing for DIR-600...Hello, If you don't have the installation disc anymore, you can...
open the setup page of the router and change the settings manually.
Like other routers, you can install wireless router without installation CD also,
Read how to setup router without installation CD
Jul 04, 2012 | D-Link DIR-600 Router
Can i hook up wrt120n to laptop without hooking up to cable modem to fix?
Try this: Unplug EVERYTHING(related to both the router and modem). BEFORE you plug in power to anything, connect all of your ethernet. So, first ethernet goes from modem to router. Make sure they are in their proper places. Next, take another ethernet cable and attach that from modem to computer. NOW, power everything up. Google the linksys router splash page login. Im sure it'll be something like: 192.168.1.1 or 192.168.0.1 or something along those lines. From there, you should be able to set up your wireless. Once thats all good, unplug just your computer and everything should be fine. If that doesn't work, its either time for a new router or you're having wifi card issues.
Apr 28, 2012 | Linksys WRT120N Router
When I try to access my cisco e1000 router on firefox or google it keeps saying that it is busy and will not connect
Are you trying to access the setup page of the router?
Did you install the Cisco connect software on your main computer?
If you have cisco connect software installed then open Cisco connect.
Go to Router settings. Click on Advanced settings. It will open the setup page of your router.
If the cisco connect is not installed then try to power cycle the router. Unplug the power to the router, wait for 30 seconds. Plug in the power cable. Wait for 30 seconds.
Now try to access the setup page.
If that is also not working then I will suggest you to reset the router and reconfigure it manually.
Watch video.
How to reset Linksys router.
Watch Video:
Linksys router setup
Feb 24, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Linksys password recovery
Computer Hope does not assist users in bypassing this security measure. If this is your router and you've forgotten the username or password we suggest that the router be hard reset and then setup with a new username and password.
Default username and password
Before doing a hard reset on the router you may want to try the default username and password. While this is not the same for all routers, this may allow you access to your router.
Username: Admin or Administrator
Password: <Blank>, try just pressing enter or try "admin" as the password as well.
If this does not work and you believe the router is using the default username and passwords try viewing the default settings at routerpasswords.com.
Resetting your router
If the default username and password doesn't work it's likely you or someone whose setup your router has enabled a password that has been forgotten. Thankfully most routers will have a small pinhole button on the back or bottom of the router (like that shown in the picture to the right), pressing this button in and holding on this button for 10-15 seconds will hard reset the router. After this has been done setup the router again and enter a username and password that you can write down.
hope this helps
Dec 21, 2011 | Linksys Wireless-G WRT54G Router
Adapter inactive
It is not the problem with the router. It is the problem with the wireless adapter on your computer. Open Network connections and look for Wireless network connection. If it is not there then open the Device Manager and look for Wireless network adapter under Network adapters. It seems that wireless adapter on your computer is not working or it is not detected by your computer. If you have external wireless adapter then unplug it and replug it.
Nov 30, 2011 | Cisco Linksys E1000 WirelessN Broadband...
My Belkin F5D8236-4 v3 Router won't turn on. We had a storm last night and the power went out but the router won't turn on. I have tried to plug it into different outlets to see if that would work...
Try resetting the router. There should be a little hole somewhere on it with a button inside that you can press with a paperclip. Try holding that button down while you unplug then plug the router in while holding it (if possible). If that doesn't work, I'd suspect the storm might've damaged the router somehow. Was it plugged into a surge protector, and/or have you noticed any other issues with anything else that was turned on at the time?
Jun 16, 2011 | Belkin F5D8236-4 Router
My router will not connect the power light keeps blinking
Check this tip out from Linksys. It is for a G VPN Router but you could use the same steps to troubleshoot. Title: Resolving Blinking Power or Diag LED on a Linksys Wireless-G VPN Router Article ID: 4982 If the Power LED on your Linksys router is blinking, this means the device is not ready. It should go off once the router completes its diagnostic test. If the Power LED won?t go off, it indicates that there?s a possible hardware problem with the router. To resolve this, you will need to perform five steps: Resetting the Router Assigning Static IP to the Computer Pinging the Router Accessing the Router?s Web-based Setup Page Updating the Router?s Firmware For instructions on how to reset the router, follow the steps below. Resetting the Router Hold in the RESET button at the back of the router for 30 seconds. Unplug the power to the router then plug it back in. If after resetting the router and the Power LED is still blinking, try resetting the router again for another 30 seconds. Then proceed with assigning a static IP address on the PC. For instructions, follow the steps below. Assigning a Static IP Address on Your Computer Most of the time, if the power LED on the router is blinking it loses its ability to assign IP addresses to the PCs connected to it, which is why you need to assign the computer a static IP address. After assigning a static IP address on the computer, check if the computer is still communicating to the router by performing a ping test. To ping the router, follow the steps below. Pinging the Router Ping test helps trace the communication between the computer and the router. The computer sends packets to the router and in return the router sends out replies to validate the connection. In this example, our router IP address is 192.168.1.1. NOTE: If you?re using Windows 98 or ME, click here. Windows 2000/XP Step 1: Click Start, then Run. Step 2: When the Run window opens, type ?cmd? in the Open field, then click OK. Step 3: When the MS DOS Prompt appears, type ?ping 192.168.1.1? and press [Enter]. Step 4: Check the ping statistics. You should get Packets: Sent =4, Received =4, Lost = 0 (0% loss). NOTE: If you?re not getting good replies from the router, it means the router is not communicating properly with the computer anymore. You can already consider the device defective. Windows 98/ME Step 1: Click Start, then Run. A window similar to Step 2 will appear. Step 2: When the Run window appears, type ?command? in the Open field, then click OK. Step 3: When the MS DOS Prompt appears, type ?ping 192.168.1.1? and press [Enter]. Step 4: Check the ping statistics. You should get Packets: Sent =4, Received =4, Lost = 0 (0% loss). NOTE: If you?re not getting good replies from the router, it means the router is not communicating properly with the computer anymore. You can already consider the device defective. If you get good responses from the router, access the router?s web-based setup page to see if a firmware update is possible. For instructions, follow the steps below. Accessing the Router?s Web-based Setup Page In order to perform a firmware update, you should be able to access the router?s web-based setup page. Updating the firmware is one way of resolving the blinking power light on the Linksys router. To access the router?s web-based setup page, click here. NOTE: If you?re having difficulties accessing the router?s web-based setup page, the router is considered defective. If you?re able to access the router?s web-based setup page, proceed in updating the firmware upgrade.
Jul 21, 2010 | Linksys Wireless-G Broadband Router
Cannot connect to router
press the reset button on the router for 30 seconds. Then unlpug the power to the router . wait for 10 seconds, plug in the power to the router.
check the IP address on the computer. try to ping the router number. if you get the replies then you will be able to open the router set up page.
Click Here for more information about the router set up
Jan 14, 2010 | Linksys Wireless-G WRT54GX Router...
Can't access Belkin setup page 192.168.2.1 anymore.
There should be a small reset pin hole in the back of the device. Hold down the reset button for 15 seconds and it should reset the router to factory defaults
May 27, 2009 | Belkin (F5D7231-4) Wireless Router
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
95 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
