Question about Samsung Digimax A7 Digital Camera
  • Anonymous Jan 01, 2008
    lens stays out even with new batterys
  • Anonymous Mar 01, 2008
    battery went flat whilst using camera, replaced batteries and now with lense out, when you turn it on it beeps 3 times and shuts down..
I had the same problem, check your batteries, I tried several different batteries and then recharged the original Samsung batteries. I also checked the battery contacts in the camera housing.
I also hooked up the USB cable to the camera and turned it on. The computer did not recognize the camera the first couple of tries. However on the third try it recognized the camera, and the lens went out and in. The little green led at the picture mode wheel stayed on and i was able to view pictures on my PC. I then unplugged the USB and turned the camera on again. The camera started up as if nothing had ever happened. I don't know if it was an actual battery problem, a battery contact problem or a software glitch in the unit. However, the camera is working fine again.
Posted on Feb 26, 2008
  • 2,985 Answers
Samsung User Support will advise whether this is replaceable under warranty or a recall for faulty manufacture
Posted on Jan 22, 2008
Samsung l60 igimax wont let me scroll and see all my pictures.turns off
The camera has an internal circuit problem that requires repairs.
Nov 27, 2012 | Samsung Digimax L60 Digital Camera
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
Samsung digimax s500/cyber530 won't start with new batteries
I have a samsung digital camera digimax cyber 530 - just replaced batteries and camera wont start, i get 3 flashes from the green light screen nw comes on then goes off & the lens wont retrack back in the camera
Oct 20, 2009 | Cameras
My samsung l830 camera lens is stuck open and when i press the power button it beeps 3 times and remains blue then does nothing
If the lens on the camera is stuck out, look to see if it's a little crooked. If it is, try to gently straighten it. If it still won't retract, try to gently push it in as you turn the power on.
If it won't turn on (the green light blinks and it beeps 3 times) push and hold the 'power' button and the 'play' button at the same time for a few seconds - it worked for my S730. Good luck!
Jun 28, 2009 | Samsung Digimax L830 Digital Camera
Turn camera on, light flashes and then turns off
i have a samsung A402 and didn't get any instructions with it.
i don't know how to turn off my flash or how to reset my camera cause there is so many icons on the screen and i cant get ride of all the icons
Sep 04, 2008 | Samsung Digimax A402 Digital Camera
It dont turn on
dont buy this c*#p again thats the best solution i can give
Jun 23, 2008 | Samsung Digimax S700 Digital Camera
Power/standby light flashes 7 times and the tv doesn't turn on
Audio Protect (7 Flash): When DC voltage is detected at the speaker or
woofer outputs, IC3604/pin128 (TV-micro) goes low and IC3604 turns off
the main power (AC relay turns OFF).
Troubleshooting Tips:
1) Main cause of defective will be located on the KD-board
2) Confi rm KD-board is securely seated on the G2-board
3) Replace KD-board
Jun 13, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Samsung s360
that's because the battery is dead.
Jun 11, 2008 | Samsung Digimax S630 Digital Camera
Samsung s630
Not a solution, but empathy. I'm having exactly the same problem.
Jun 08, 2008 | Samsung Digimax S630 Digital Camera
Samsung Digimax A7 Digital Camera Logo
81 people viewed this question
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
