Question about GE GSS20IEP Side by Side Refrigerator
The tube freezes over where water comes in to fill the ice tray
The tube where the water comes in and fills the ice tray is constantly freezing over. Once this happens no more water comes in. Which results in no ice cubes. Once i clear the ice chunk out of the tube i get a few batches of ice then its frozen again. I also have a secondary problem. The flapper where you put your cup and wait for the ice doesnt close all the way. I have to manually close it. Not sure if this could be the problem.
  • 2 more comments
  • holycrap Dec 26, 2007
    Does anyone have any ideas
  • jasper31 Jan 21, 2008
    I have the exact same problem with my tube that fills the ice tray. After it freezes, it still call for water and somehow the water sprays in the freezer causing a big ice mess.
  • edlee Nov 23, 2008
    I have GE refer one year old, top freezer. This inlet tube freezes solid about every 2 weeks to 4 weeks. I have to remove the ice maker, remove the tube, remove the ice, and reinstall. The problem is not just not getting ice, water dribbles out the tube assembly due to the back pressure and ruins the floor.
  • Anonymous Feb 25, 2009
    We have the same problem. To date, my work around has been to pull the ice tray out and use my wifes blow dryer to thaw the ice in the tube. however, ~48 hrs later the tube freezes solid again. When this happens water sprays out the back, which soaks the floor and my basement ceiling. very frustrating!!!!
    Along these same lines I have a GE dishwasher that has similar problems.
Check for water leaking after you clear the ice next time
if it is leaking some change the water valve in the back
Posted on Mar 04, 2009
    Sergeant:
  • 288 Answers
You may have a related problem. If the freezer compartment isn't sealing off it will have excess moisture inside eventually making excess ice build up on the water inlet tube on the ice maker. Otherwise the water inlet valve is not closing completely and a little bit of water is building up and freezing.
Posted on Dec 26, 2007
I LIKE POOP
Posted on Nov 19, 2008
Ice maker won't make ice
most times I see the tray and fill tube ice up its due to a leaky fill valve , this valve should close tight after filling tray , but sometimes they leak just slightly then everything freezes up in a block of ice
fill valves on most all units is located in back lower left corner , just follow the water line in the back of unit
Jan 15, 2016 | True Refrigerators
How do I stop my ice maker water filler hose from freezing - which stops water from filling the tray?
This problem is caused by a defective water control valve that does not stop leaking water like a dripping faucet. This causes water to freeze in the water fill tube thus blocking fill of ice tray. Replace water control valve.
Appliance 911 Sea Breeze
Sep 19, 2015 | LG Refrigerators
Ice maker fill tube freezing
There is a possibility that the water valve isn't closing completely leaving just enough space for a drop or two of water to make its way and freeze in the tube, but more than likely the fill tube is a plastic one and little divots have formed retaining water and freezing up. These divots may not even be visible to the ***** eye. A good solution is to switch to a rubber fill tube which is less likely to have this problem.
Jun 16, 2012 | GE Refrigerators
Ice tray filler tube freezes up and clogs up so no water goes into tray
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
May 22, 2010 | Amana SXD524VW Side by Side Refrigerator
Not making ice
Sep 24, 2009 | GALAXY Microsystems 25.4 cu. ft....
My icemaker is not working. Water not filling tray
Probably the valve that feeds water to the ice maker leaks and this water freezes up at the filling tube to the ice maker and the water doesn't go through, but if the filling tube is not frozen and the ice maker doesn't call for water the problem is in the ice maker inside board ,if so you should replace the ice maker.
Jul 14, 2009 | Refrigerators
Ice maker shuts off when not used
Check to be sure water line is clear of hard water or Ice.
Jul 02, 2009 | Refrigerators
I ice maker keeps freezing in our side by side GE fridge.
This annoying problem can have a variety of causes. Check these four things first:
  1. Make sure the water supply is greater than 20 psi. If too low, thewater valve won’t seat properly and it’ll “weep.” Common causes of lowpressure are gunked-up saddle tap valves, kinked water supply line, andusing a reverse osmosis filter to supply water to the icemaker.
  2. Check between the valve diaphram and valve seat for sediment. If found, do not attempt to repair, buy a new valve.
  3. Check to see if the black, flexible portion of the fill tube iswrinkled, twisted, or kinked which can cause ice dams that block thefill tube.
  4. Find out if the water has been shut off while the icemaker has kepton cycling. This, too, can cause the fill tube to freeze up.
If all the above checks out and you’re still getting fill tube freeze-ups,then best get a service guy to take a look. It could be a complicated repair.
Jun 24, 2009 | Whirlpool ED2FHEXN Side by Side...
Water freezes before getting to ice tray
sounds as if your water inlet valve is not closing fast enough allowing a small amoutn of water to accummulate in fill tube freezing and eventually freezing solid, would try replacing water inlet valve, or even the water filter if this model is so equipped
Feb 18, 2008 | Refrigerators
Ice maker freezes up
Icemaker Fill Tube Freezing Make sure the water supply is greater than 20 psi. If too low, the water valve won't seat properly and it'll "weep." Common causes of low pressure are gunked-up saddle tap valves, kinked water supply line, and using a reverse osmosis filter to supply water to the icemaker. Check to see if the black, flexible portion of the fill tube is wrinkled, twisted, or kinked which can cause ice dams that block the fill tube. It turns out that the manufacturer's have been scratching their heads about this, too, and have concluded that the new fill tube air slit design helps prevent this problem.
Apr 10, 2006 | U-Line CO2075F-B Echelon Refrigerator Ice...
GE GSS20IEP Side by Side Refrigerator Logo
204 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
