Question about IBM ThinkPad T21 Notebook
Ethernet card not detecting
i am trying to install ethernet card in my dell c610 laptop, but it's not detecting at all. is there i need to do something in bios? it's already enable in bios.
  • 243 Answers
Are you meaning a slide in one in the pcmcia slot? Does the laptop make a noise at all when its inserted?
Posted on Dec 29, 2007
Why wont my inspiron dell laptop feed internet
check if ethernet card is detected in device manager or not if yes
update the drivers fro
if still dosent work try to use external ethernet card.
Apr 01, 2010 | Dell INSPIRON 6000 CENTRINO...
I recently had my hp pavillion dv 2000 with windows 2000 crash and it has been repaired but I am unable to connect to the internet. Turns out after a check I am missing my Ethernet card what can i do...
I the Ethernet card removed complete from your system or you mean to say your system do not detect your Ethernet card.
If the system do not detect your Ethernet card, then it is more of drivers related issues.
Re-install the drivers of your Ethernet card and try to connect.
This should solve your issue.
If there is no Ethernet card in laptop. Then, get one, install drivers for the same.. and try to connect. It will work.
Nov 04, 2009 | HP Pavilion dv2000t Notebook
Replacing ethernet PCI card 10/100 by gibabit 1000
When you replace and install LAN card you need to install also the driver. Be sure that your onboard ethernet PCI card are disabled in BIOS. So that the new install LAN card are working.
Sep 26, 2009 | Dell Ethernet Card Network Adapter
My Ethernet card doesn't work on my n845wn Intel
It's possible the drivers are not installed.. To check if drivers are properly installed for the Ethernet card, if you have win XP
* go to Start>Control Panel>System> click on Hardware tab, then Device Manager
- once you're on Device Manager, look for network adapter, you should see something like "Via Rhine II Fast Ethernet Adapter", this is just an example, you may have a different brand of Ethernet adapter
- if you can see the Ethernet Adapter and it has a green icon beside it, it should be working fine, you can also double click on it, to view the Status
- if you don't see the Ethernet Adapter on the list, look under the section "Other Devices", if you see an "Ethernet Controller" on the list with a yellow exclamation point, it means the drivers for the Ethernet Adapter were not installed, which means the drivers has to be re-installed
- you need the manufacturer cd for the drivers
*Now if there's no "Ethernet Controller" on Other Devices section, it's possible the Ethernet card is not being detected by the computer
- you may have to unplug the Ethernet card physically from the computer (computer must be completely turned off) then try to insert the Ethernet card again and boot up the computer, if the computer detects the Ethernet card, you need to install the drivers
- If the computer doesn't detect the Ethernet card, most probably it's busted. You may have to replace it.. You can also try to install the Ethernet card on a different computer just to check if it's really the Ethernet card or the motherboard that's the problem..
May 10, 2009 | Intel Desktop Board D845WN Motherboard
Ethernet port not "active"
Hi there.
Restart the PC and go into the bios to make sure the on-board LAN is enabled, if it is try as jery says and try another ethernet cable.
Post back please and good luck
Apr 21, 2009 | Dell Latitude C400 Notebook
Questions about replacing ethernet card on my Dell desktop
Any ethernet card will work fine. Just be sure it's the fit's the correct slot. You probably have a "white" slot which is a pci slot. If it's a longer "black" slot then it's isa. More than likely it came from a pci slot. Before you buy one, confirm the type of slot. In additon, before installing it go to control panel and system settings, hardware, device manager and remove the old one by right clicking it and select delete or remove. Shut down the computer follow instructions for new card.
Probably will have to install the drivers first then shut down and install the new card. Good Luck.
Apr 17, 2009 | Dell Ethernet Card Network Adapter
Ethernet controller has a yellow ! makr after it
reinstall the ethernet adapter driver from the dell drivers and utilities and extract the necessary ethernet driver under network driver
Apr 04, 2009 | Dell Latitude C610 Notebook
Unable to connect to internet
What do you mean by "reloading Windows"? Did you repair it? Maybe did reinstallation? If so, you may need to install drivers for your Ethernet adapter. You will need to specify Ethernet adapter manufacturer and model (if it is onboard adapter, then motherboard manufacturer and model), so I can provide you with the download link, in case you don't have the drivers.
Your responses are intended to improve the level of service provided. Please rate your experience.
Jan 17, 2009 | Dell Inspiron 1525 Laptop Jet Black
Laptop computer wireless problem
i have no sonud device install in my laptop , please tell me how can i install the sound device
Sep 29, 2008 | Dell Latitude C610 Notebook
Ethernet for Dell Dimension 2400?
You need to install the ethernet card driver of your system,
hope this solve:
If the ethernet is not detected and it is built in to motherboard maybe is damage
If not built in; try to transfere the card to the other slot beside or its equivalent slot.
If not solve the problems;
Time to buy new ethernet card. You can buy any ethernet card for broad band connection.
Jan 02, 2008 | Dell Dimension 2400 PC Desktop
IBM ThinkPad T21 Notebook Logo
52 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
