I need to know what the indicator symbols mean on RAV4
I need to know what the indicator symbols mean on the dash. I lost my manual and my ! with a triangle around it came on. I'm not sure if I should take to a dealer or not
Security and Immobilizer System Indicator Symbols
Symbols & Tell-tales
These are Security and/or Immobilizer System Indicatorsymbols used by manufacturers. One of these symbols lights momentarily to indicate that the ignition switch is locked and will need the proper transponder-equipped key to re-start. The vehicle is immobilized otherwise. Green symbols will flash when the vehicle is immobilized.
If the symbol is visible when the vehicle is on, it indicates a malfunction in the security system. If the engine does not start with the correct key, and the security indicator remains on, the system may have a malfunction. You will need to contact your dealer in either case.
Keep the Symbol meanings with you!
you can look in your glove box and find the manual book. you will be able to find the symbol and what it means. It could be serious or just a minor oxygen sensor. Can you show what the symbol looks like?
You need a scanner to pull out the engine light codes.
Use a shopu manual to aid you with the diagnosis and repair.
The slip indicator and vsc light being on means these systems are not working. Once you pull the codes and do the repair and erase the codes the lights will go off.
There will be a code in there for the misfiring.
Good luck and keep me posted.
that symbol is for your tire preasure,its telling you that one of your tires are low, check all tire preasures, you can set to32 psi or look in manually sometimes they have you set them at 28psi but i always go to 32 psi. anyway theres a button on the lower left of steering wheel to reset or drive a few miles.also check your spare, hope this helps.
