Question about Brother HL-2040 Laser Printer
Spots on copy
I started to get a few grey bands on the print copies, then it turned to heavy random spotting with spots of various sizes.
  • romdue Dec 29, 2007
    new machine. cheap toner. Thanks
  • Brother Master
  • 1,113 Answers
Clean carona on drum. blue slidy tab, sounds like you are using non brother toner is that correct? Replace with OEM, Can also be worn drum
Posted on Dec 28, 2007
Oki mb470 pages are not printing properly
It may be time to replace the drum. Check to see if the light spots are random or if they appear at regular intervals. Regular intervals would indicate something in the paper path, typically the drum. But don't rule out the fuser.
May 01, 2014 | Oki Electric Industry OKI MB470 (A4) Mono...
Magenta toner spots pages
Step 1:
Print out about 10 blank (all white) sheets and see if the spots clean off.
Step 2:
Check to see if the toner is Dell type brand, if not try installing Dell brand and run 10 blank copies then run color test print using menu key.
Press menu, press arrow down key till 'print reports' is displayed, Press 'check key' then press down key till 'color test print' Press check key to print color copy.
Apr 10, 2013 | Dell 3010cn Laser Printer
Irregular ink spots all over the text
Are the ink spots in the same pattern down the page ? if so it sounds like a bad drum. try and make a copy using only one color at a time, to try and tell which drum it may be. If the spot are random down the page it may be the ITB belt cleaner.
Apr 17, 2010 | Canon imageRUNNER C3200 Copier
Paper when out put then see spot in middle page portate
I don't know the model of Canon Copier you have, and I don't know if your problem happens when you copy and print, or only when you copy, so it's hard to tell with the little information you've provided.
Let's assume the easiest solution is the correct one...
Is the "Spot" in the same location on every copy? Then clean glass.
does the spot move left to right across the page with each successive copy? Then replace the drum unit.
Sep 10, 2009 | Canon Office Equipment & Supplies
Tried to clean the rollers
If the spot appears in the same exact location, you should clean the copy glass but if the spots are in the random area at the same line you should check the drum seal of the drum unit. The seal purpose is to prevent the waste toner from spilling to the drum and copy paper
Jun 24, 2009 | Sharp AL-1641CS Laser Digital Copier
Are the dark spots random and moves location with every copy or are they at exacly the same place on every copy? Random you will need to remove the drum/toner and use a blower to clean the inside of the machine,failing that replace the drum unit.If the spots don't move clean the top glass.Let me know
May 21, 2009 | Sharp AL-1641CS Laser Digital Copier
Grey paper on copy.
unfortunately this is not a fix yourself problem.
1- seperation could be bad
2-bad toner or developer
3- could be as easy as cleaning the mirrors
try to find a tech that works on the side, or freelances for no more than $40-75 depending on the complexity.
Aug 08, 2008 | Ricoh Aficio 450 Copier
White spots with a black dot in the centre
pls check the ibt belt. its geting any hole are bunch its come like this, or u will check and clean ibt assemply transfer rolleres. and 2nd btr also.
Jul 23, 2008 | Xerox DocuColor 12 Color Copier
Black Spots all over my copies
There are lots of things that can cause this. Inspect the fuser assembly & verify that there isn't any teflon missing from the upper roller & that the lower roller is clean. The spots can also be caused by a build up of waste toner in the cleaning assembly, causing excess toner to be dropped on the copies as they pass under it. The cleaning assembly would need to be removed & cleaned to correct this. The spots are not always in the same place - but are they the same pattern? A worn drum assembly can cause spots that are usually a repeating pattern but located in different parts of multiple copies. Dirty corona wires can also cause random spots & rewiring the coronas would solve that.
Jun 11, 2007 | Toshiba DP2570 Printer
Brother HL-2040 Laser Printer Logo
429 people viewed this question
James Cagle
James Cagle
Jim Keysor
