Question about Dell (04U621) for Latitude D600, Inspiron 600M Motherboard
Computer keeps shutting down
The problem I am having with my 600, is that on boot up, it will either complete the boot to XP then then freeze up, which needs a reboot. Or, will not boot initially and the letter A light, flashes, then the laptop shuts down. Any ideas?
Did you download the latest drivers from dell web page? I had a similar problem with my Dell D620. The problem was the chipset drivers. I downloaded the chipset drivers from dell and the the problem disappeared.
Posted on Dec 27, 2007
Hi, My Samsung R580 I3 JBB2-US keeps on shutting down. If I close the lid when I re-open it shuts down & I have to restart or it freezes and I have to force restart. Sometimes when I boot up it...
You can try go to Start - Control Panel - Power Options and check what you want computer do when you close the lid of your laptop. Fix that and restart laptop to apply the setting.
If the boot up not complete and restart by itself, in my opinon, there is something wrong on the start up process, could be hardware malfuctions, could be a software not compatible. Try check the start up process to see.(use Start- Run: msconfig)
If this happen often, you should call the Samsung customer services to find out. Laptop i3 should still under warranty.
Hope this will help.
Thanks for reading
Jul 20, 2011 | Samsung R580 Notebook
I have Aspire T135 and everytime I boot the PC, it freezes at the Windows XP logo screen right before going into Windows. I checked memory, hdd, cdrom, etc. I installed a PCI slot video card and changed...
try booting in safe mode, and watch as the drivers are opened, as safe mode boots. take note of the last driver or file which it stops on before freezing or resetting, then look up (google) the name of the file or driver (.dll file), to find out where your problem is. if it turns out to be a driver file associated with your phone modem, then it is your phone modem which is preventing the computer from starting.
if that doesnt work, then strip the computer down completely to 1 ram stick, the cpu, mobo, video card (or integrated) and 1 hard drive. disable any unnecesarry integrated components (such as the soundcard) in BIOS, and remove any usb devices or pci cards which are not absolutely necessary to boot the computer (such as a phone modem card, an external hard drive or wireless network card).
the computer should boot once stripped down to the bare essentials and all unnecessary hard ware is disabled/removed. if it boots, then add back/reenable your extra cards, and devices one at a time, until you find the device which is keeping it from booting.
if it will still not boot when stripped down, then it is an essential, such as the motherboard, which is at fault.
Oct 28, 2010 | Acer Aspire T135 PC Desktop
Having problem shutting down. Computer freezes when process gets to Windows shutting down. have to use the power button to complete shut down. Help!!!
if your are using xp - it seems that u had not install xp service pack2 &3 it will resolve this issue kindly download the sp2 & 3 for ure xp. after installing sp2 & 3 u r facing problem let me know.
May 15, 2010 | Acer Aspire 5100 Notebook
Windows XP boots re-boots after installation of SP2
try removing 1 RAM then let it boot completely,
Aftrer a success boot shut it down then put back the RAM that you removed
if the above solution did not work reformat your PC and repartition it
pls rate if this thing helps
Jan 30, 2010 | Computers & Internet
My mouse keeps freezing
Blue screen is not a good sign at all. It can man alot of things, the driver is not right, you have a virus on your computer, or someone is in your computer. I would go and get and good firewall program or use xp or vista firewall. If that doesn't work then you do have virus. I would do a complete refresh on the system longest you have the recovery disk.
Aug 09, 2009 | Dell Vostro 1510 Motherboard System Board...
Windows freezes when shutting down
If you can download the lastest bios for that PC from the internet that should fix your problem if that does fix issue reinstalling windows or does Xp restore from cds will
Mar 18, 2009 | Asrock K7S41GX Motherboard
No "press any key to boot from cd" message
ok if it is windows xp and u want to format it then what u can try is that if u have the option for the complete pc restore,then what u need to do is that shut down the computer completely and then all u need to do is that shut down the computer completely from the power button and then press and hold down the "ctrl" button and then press the power button only once and keep tapping the f11 key on the keyboard....and follow the instruction that says complete factory setting and then it will give u some message from symantec and then click on ok and the computer will be format,all u need to do is follow the instruction very carefully.....
or u can try once again,shut down the computer and then press the power button only once and keep tapping f12 key on the keyboard and then highlight the cd drive and then put nthe xp disk in and keep tapping enter and enter and enter untill it will take u to the windows set up screen and then it will give u the option to press R to repair and esc to continue and press esc on the keyboard and then delete all the partition the instructuin will be given just read it carefully and it will be formatted........hope this will work take care...
Jan 27, 2009 | Microsoft Windows XP Professional
1) Start up sometimes freezes, 2) Is not recognizing outlet power
Hi.
i recommend You in this Case to format and install a new OS
Windowns XP.
good luck
Dec 12, 2008 | Acer Aspire 3002LCi Notebook
Computer does not boot up completely -shuts down by itself
for xp there was a update called service pack 3 witch caused alot of compaq to just boot the shut off this seems to be ur problem although i am not sure of ur pc's brand hope this helps
Here to Help
Shaun
Nov 24, 2008 | Computers & Internet
Computers & Internet Logo
141 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
