Question about Hotpoint Aquarius WMA42 Front Load Washer
Cycle hi the washing machine doesnt go through its full cycle before final spin it stops can you help please
  • radoxpool Dec 26, 2007
    hi have same problem can anyone help?
Clean the drain filter ( It says its self cleaning but its not).
On my Hotpoint Aquarius WD440 the procedure is as folows:
1) Drain as best as possible, switch off electrics at socket
2) Remove the plastic panel at the back of the machine
3)Locate the large diameter short black flexi drain hose on the right hand side
4)Slacken the screw on the TOP jubilee clip (The one holding the hose to the drum ) until the rubber hose can slide off
5) The plastic filter is inside the end of the hose. Remove it, disassemble and clean it - then reassemble it remembering to re-insert the ball inside the filter
6) Put the filter back in the hose, there are 2 slots which will locate on two ribs on the drum
7) Refit the hose and re-tighten the jubilee clip.
Posted on Nov 04, 2008
  • 1,294 Answers
Plug off the wall. Open up behind the machine. Check to see if any wires loose. See that the wires from the control panel to the motor are plugged in tight. Vibration from the machine could loosen the wires and give the display wrong readings, or disrupt the run.
Rate me please..........
Posted on Dec 26, 2007
Brand new Bravos. Why doesn't it do the final spin?
May 26, 2015 | Maytag Washing Machines
Whirlpool duet front loading machine stops before the final spin cycle, leaving loads full of water. Prior to stopping the display shows 18 to 22 minutes left in the cycle, but suddenly stops. There is no...
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Aug 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My f&p smartdrive washing machine does every cycle except the last spin cycle. it drains the water out but doesnt spin the clothes
Hi just read your posting.Could you please supply the model number of your machine for me.The model number is located on a sticker at the back of the machine top left.Does your machine stop and beep and show an error code?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Sep 26, 2010 | Washing Machines
Spin cycle slow unless hose lowered
you will have to take the hoses off the pump and clean the pump out its probably got sand in it
Apr 23, 2009 | Washing Machines
Damp clothes at end of spin cycle
Time to check out and clean your filter...........
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
My Kitchenaid washer stops on the rinse cycle...
Do you have an age of the machine and model number? Is there a "spin only" cycle? On older machines, there was a center knob you could slowly rotate, one click at a time, to advance it through its cycle. Can you do that? If the unit is agitating, I don't believe the belt is your issue. Age and model please.
Jul 31, 2017 | KitchenAid KAWS750L Top Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Fisher/Paykel Smart-drive 5.5 auto washing machine was on final spin cycle and starte making unbalanced load noises. I stopped it,redistributed load and tried to restart. It restarted in spasms so I took...
sound like the controller opr micro board is sick. unplug leave off for a few minutes then power up again and try empty wash cycle if its the same call the engineers.
Apr 22, 2008 | Washing Machines
No final spin
I haven't experienced that problem, but is it possible that the machine becomes unbalanced with the spinning load and then aborts the spin, so it doesn't finish? Has the machine been properly leveled during installation?
Apr 09, 2008 | Malber WD1000 Front Load Washer/Dryer
check that the outflow pipe is not blocked. Turn off power supply get a bucket ready, disconnect the outflow pipe from the u-bend under the sink and check that it is not blocked.
Mar 15, 2008 | Hotpoint WMA46 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
236 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
