Question about Canon PIXMA MP600 all-In-One InkJet Printer
Error code: U150 The following ink tank cannon be recognized (Cyan)
I cannot print (or clean) my printer due to the above message. The Cyan Cartridge used to work fine, and it's still 70 % full. I reinstalled the blue ink cartridge several time, turned the printer off and on, but the same message keeps appearing. When I push the cartridge in, the printer seems to recognize the cartrdige, as the red light turns on, but when I close the printer, the U150 message appears. What can I do? I hope you can help me.
  • 17 more comments
  • Anonymous Dec 28, 2007
    I have a different model but mine does the same exact thing that you described and I'm always out buying ink cartridges. Replacing ones that are still full. It's annoying. I'd also love to know a solution. No help from Canon support.
  • Anonymous Jan 12, 2008
    Have exactly the same problem. Did not try a new ink tank as the current one is full, and it had been working ok for some time.
  • Anonymous Jan 31, 2008
    I have exactly the same problem with my Canon MP600 printer (cartridge not recognised). It looks like that there is a fault with this printer that only affects the cyan cartridge. Surely Canon must be well aware of this problem. I am now awaiting reply from Canon Customer Support.
  • Relayer56 Feb 05, 2008
    I have the same problem, only mine is not recognizing the black cartridge (PGI-5BK). On the phone now with tech support... he says he will send me another printer... waiting for him to come back online... don't know if that's a new or refurbished... ok, probably a refurb... can possibly send me to a certified repair center....
    Well, I'm going to call the repair center to see what they say before I decide which way to go.
  • Anonymous Feb 16, 2008
    Yes, I have the same problem with both the cyan and yellow cartridges. It just started out of the blue. I have to turn the printer off and on again and it then works OK. Weird hey! I've been so impressed by the print quality but this is really annoying. I've had the printer for 11 months and it's worked beautifully until now!
  • Jazziesdog Mar 05, 2008
    I cannot print my printer due to the above message. The Cyan Cartridge used to work fine, and it's still 95% full and put a new one in same problem I reinstalled the blue ink cartridge several time, turned the printer off and on, but the same message keeps appearing. When I push the cartridge in, the printer seems to recognize the cartrdige, as the red light turns on, but when I close the printer, the U150 message appears.
  • Anonymous May 11, 2008
    Have same problem with yellow cartridge [CLI-8Y]. Half full. Came our of blue.
    All other help sites do not publish a solution. HELP!
  • krussell2003 Jul 12, 2008
    I have the same problem with the cyan tank. I replaced the tank when it was over half full and a week later, got the same message again on the cyan tank.Any suggestions on fixing it?
  • Anonymous Jul 21, 2008
    My printer says the following ink tank can not be recongized. It's the black ink cartridge. HELP!
  • tsfabco67 Aug 06, 2008
    I bought my printer 6 months ago and used it very little I still have more than 90% ink for color Magent and each time I tun it on or remove the cartiage and but it back in it's place I get the message
    "The following ink tank cannot be recognized"
    Which stops me from printing.
    How can I fix this problem.
    Please advise
  • bill112 Aug 10, 2008
    remove cartridge and put back in, plenty of ink always have had problems with cyan does not rec. have cleaned and deep cleaned
  • NZ Whitegirl Aug 26, 2008
    iv been having the same probs but with the pink one :'( i rang Noal Lemming, Palmerston North, NEW ZEALAND on 06 3530114 and they said i have a extended warrenty for 3 years so to just bring it in and they will sort it. but i said there r millions of others that r having the same problems and what r they ment to do if they DONT have extened warrentys, and the guy (typical nobrain salesman) said i duno. i asked for canon's 0800 (freecall in NZ) number and got alot more joy :> the freecalling NZ number is 0800 222 666 (pick option 3, to save time being put on the "ill just put you thru to someone else, WHO CAN HELP" merry go round). he said by the sounds of what iv found and been reading on online help site's that it is prob more likely to be a fault with the ink tank chip thingy on the front at the bottom of the ink tank, andd took a few details and is sending me a new one in the post. and if that doesnt solve the prob, we will THEN go to the next step. i hope this does give some of you out there a bit of insite to the hundreds and thousands of faults with the same problem. and to those that read the thingy about fixing it with masking tape, i tried and tried this, spent 3 F__KING hours doing it and it DIDNT WORK, it only mad me more pissed of and frustrated :'( in the future, i recommened ringing help and support in your own country before getting advice from an online site that is not from the manufactures :) good luck to all :) ill post another comment again if getting a new pink ink tank thingy posted to my home for FREE DOES NOT WORK!!! cheers for the help and advice
    Kat AKA NZ WhiteGirl
  • mpm313 Nov 03, 2008
    This is the third cartridge this has happened to. This is also my LAST canon product, what a total ripoff!
  • Anonymous Nov 16, 2008
    My printer has the same problem, U150 Cyan. The ink cartridge is 90% full and was replaced less than 4 months ago. This error has basicly made this machine useless. I am very dissapointed with Canon.
    150 with a full cartridge
  • Anonymous Nov 23, 2008
    u150,useless printer!
  • MrRoo Mar 30, 2009
    MP600 7 Months old only printed 50 pages max, half ink in all cartridges but printer says cannot recognise them. Bought new but same problem. Another £120.00 wasted on a printer that is not fit for purpose SIMPLE DONT PURCHASE ANYTHING FROM CANON THEY ARE A WASTE OF TIME
  • Anonymous Mar 13, 2014
    code U150
  • Anonymous Mar 20, 2014
    an error keeps appearing on my mx510 printer, I have reset it and turned it on an off,what can I do?
  • 3 Answers
U150 ink error fixed!
I too was getting the error for unrecognized ink cartridge. Then the little green circ board fell out of the end of the ink cartridge and it hit me that maybe if I put in the little green circ board from the old ink cartridge of the same color, then maybe the ink cartridge would be recognized. It worked! So don't throw out an ink cartridge that still has ink just because of that error and hold onto your empty cartridges in case you need the little green/gold circ boards.
This works!
Posted on Aug 04, 2008
  • Nance Baird
    Nance Baird Jan 16, 2014
    You are BRILLIANT! This worked like a charm. THX!!
The U150 problem is all too common and apparently there is no fix other than replacing the ink tank the error code refers to. I've gone through cartridges in the past 3 months, all of which were original Canon products and were over 50% full. From experience, this U150 error can happen to any ink tank and it completely shuts the printer off from any further use.
Before I bought the printer I read rave reviews about Canon printers. Looks like we all got duped.
Posted on May 13, 2008
The good news: Office Depot replaces "damaged" cartridges. This is my only solution to this problem. At least we'll get our money back. This is certainly an issue, Canon has to solve. Other than that I think this printer is much better than other products in this price range.
Posted on May 14, 2008
Hi, I refilled cartridge CLI-526M fromCanon Prixma MG5250 and I have the error U130. How can I resolve the error to reprint? Thanks.
FAQ: An Error Message Is Displayed on the LCD
If an error message is displayed on the LCD, take the corresponding action described below.
The following ink may have run out. Replacing the ink tank is recommended. U041 Print head is not installed.Install the print head.U051 / The type of print head is incorrect.Install the correct print head.U052 Some ink tanks are not installed in place. U072 / More than one ink tank of the following color is installed. U071 The remaining level of the following ink cannot be correctly detected. Replace the ink tank. U130 The following ink tank cannot be recognized. U043 U140 U150 The following ink has run out. Replace the ink tank. U163 There are no photos in memory card Contact the support center or service center for ink absorber replacement. Press OK to continue printing Ink absorber full. Service required Timeout error has occurred The device may be incompatible. Remove the device and check the manual supplied with the connected device An unsupported USB hub is connected. Remove the hub. B200Printer error has occurred. See the manual **** Printer error has occurred. Turn off power then back on again. If problem persists, see the manual
Jul 06, 2011 | Canon MG5250 Printer
Error code U150 The following ink tank cannot be recognized
First, make sure you have the right ink cartridges. Here are the right codes: CLI-8BK and PGI-5BK for black, Yellow - CLI-8Y, Magenta - CLI-8M, Cyan - CLI-8C.
If the ink lamp is off then an ink tank error has occurred. Try to remove the ink tank and re-seat it. Make sure you removed the plastic cover on the ink tank. If nothing helped, you need to replace the faulty ink tank.
Dec 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
Nov 06, 2008 | Office Equipment & Supplies
Canon IP6600D Error Message U150
you need to reset the chip on the ink cartridge.......................
Aug 22, 2008 | Canon Pixma iP6600D InkJet Photo Printer
MP500 ink tank cannot be recognized error U043
I had the same problem. My mp630 is also only 4 months old. I replaced all colour ink cartrdiges(inc black), but was only able to release the function for detecting the ink levels for magenta and cyan. Yellow and black then started giving error message U043, with them alternating between working, but never working at the same time. Getting them all clicked in with the lights glowing red does not solve the problem, as once the printer cover is closed, the same error message turns up. The only thing that worked for me is moving the chip slightly out of alignment, by pushing the sliding chip holder, and I only had to do this twice before they all started working and the printer was unlocked.
Jul 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Error messages: U150 + Ink tank errors have occured
Reset Canon MP600 to the Factory Setting
  1. Press the HOME button.
  2. Use the Easy-Scroll Wheel or the right/left arrow to select Settings, and then press OK button.
  3. Use the Easy-Scroll Wheel or the right/left arrow to select Device settings, then press the OK button.
  4. Use the Easy-Scroll Wheel (B) or the up/down arrow to select Reset settings, then press the OK button.
  5. Use the Easy-Scroll wheel or the up/down arrow to select Yes on the confirmation screen and then press OK.
  6. Press the HOME button to return to the HOME menu.
Jul 12, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Pixma mp500
  • Replace a new Canon ink cartridge as it could be due to the unique features that Canon has build on their ink cartridge not done properly which resulted to be faulty. Report the issue to Canon if your existing ink cartridge is not from other 3rd party band, Canon should be able to do 1 to 1 exchange once confirmed that it is their ink cartridge problem. Cannon has build the unique feature to prevent users from misusing 3rd party ink cartridge on their printer.
  • Other times if by replacing new ink cartridge the problem for error code still occurs, it might be the pin on the print-head has lost the alighting, this will require for Canon to service to alight back the pin on print-head in order for the printer to operate smoothly again.
  • Or missing pin has dropped off from the print-head which causes the printer not able to read the ink cartridge, printer needs to be serviced.
  • (Maybe check with your own nearby technician if by any lucks they can help to rescue your printer, which I hope Canon does not have further enhancement on their printer with other Unique features to prevent users from using 3rd party technical support.)
Nov 25, 2007 | Canon Pixma MP500 All-In-One InkJet...
I have a canon mp510 pixma same message U043 and a u150 fault.
I cant see any chip to replace and have replaced my original cartridges with a non branded cheaper type, this might be why. Does this make a difference or is this the same problem occurring with replacement canon cartridges as well.
Dont want to buy genuine ones if its not going to make any difference.
Anyone who can help me would be appreciated
Nov 14, 2007 | Office Equipment & Supplies
Canon pixma mp500
Hey- i just wanted to say that I had the same problem with my MP600. Unlike some people, I have a problem buying ripoff cartridges from a store. I use my printer alot and I simply refill these. You can buy any refill kit and especially with these cartridges, drill a hole near the top and just fill it and plug it. The sponge sucks it up and you're all set. As far as the Chip problem-it is a pain in the ass and the **** at Canon probably won't fix it. HOWEVER, if you still want to print and don't mind that your ink counter says that you are empty simply hold the "STOP/RESET" and the "Black" print button together until it clears and you'll be set. I do it all the time and I know it works on the later MPs. Check it out and stick it to the man
Nov 12, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
4,674 people viewed this question
old marine
old marine
