Question about Compaq Evo N410C Notebook
Evo N410c- Won't boot
When power plugged in, LED's will illuminate after 3-5 seconds, but no fan or HD startup. If you hit the power button, the lites will immediately turn off. There is a slight speaker pop at this point. After a few seconds, the LED's will come back on. I have tested w/ three different PS. Same results.
Checked the HD, it's fine. This happened several months back, and it started working after I opened it up. No idea what caused to it to work. Then failed as quickly.
Where do I start?
  • mmccoy3636 Dec 27, 2007
    Can't get that far. Won't boot or power other than the start-up LEDs.
    You think I should check the battery? That could keep it from booting?
    The AC Adapter is good. I have three! All within spec... Now the plug on the MB is a bit suspect.. I found a used MB and ordered yesterday. Hate to go that extreme, but may have to. I'll pull the battery and see what that shows. Thanks. Any other ideas?
  • Anonymous Mar 18, 2008
    hard disk dead
    Sergeant:
  • 263 Answers
Can you go to the bios info? if yes check the time if that is rong change the inetrnal batery and loock for the hd and the boot order set to 1st hd than save that and see what does now if you can not go to bios so you have to check the batery and the ac adapter
Posted on Dec 27, 2007
Screen says initializing
You may have a faulty battery/phone. This seems to be a common problem with this type of phone. If you can take it and have them check it for SAFETY CONCERNS That would be ideal, as they can reset it for you.
Caution! This WILL erase everything on the phone. You will have to confirm you want to do this before it will complete. (This is why you backup your phone. You may wish to remove the SD card FIRST.)
1. Ensure the device is powered off.
2. Press and hold the Power button for 3 seconds then release.
3. With the LED illuminated red, press and hold the Power button+Volume down key+Camera key simultaneuously then release.
The LED illuminates approximately 20-30 seconds after releasing the power button (step 2). The 3-key combination must be pressed within the 1-2 second timeframe that the LED is illuminated.
4. Press the Power button to confirm and continue.
5. Again, press the Power button to confirm and continue.
( Allow several minutes for the factory data reset and reboot processes to complete.)
Oct 18, 2013 | Casio Cell Phones
How can i reboot my PC without keyboard?
Here are some of the steps to you can reboot your pc without using a keyboard:
1) Long press the power button
- Press the power button for about 3-5 seconds. If the power LED or power supply fan shuts off, that means you have successfully turn off your pc. Press it again to turn on.
2) Unplug the power cord from the power supply
- Force your pc to shutdown by unplugging the power cord from the power supply of your pc. Put it back again and press power button to turn on.
Note: Please make sure you have saved important activities before doing this as this will immediately turn off your pc.
Hope it helps.
Thanks!
Feb 22, 2011 | Computers & Internet
Basically i plugged in the ac adapter to it, pressed the power button and the power light comes on for 2-3 seconds then the power light shuts off. lcd screen never turned on or show anything, fan never...
>>> Please leave feedback so I can continue helping You & Others
The middle blue led is the charging indicator, sounds like you have (at least) a bad battery, remove it, plug in AC and try again, if no good, remove the HD and repeat, if no good, remove/replace the ram and repeat, if still no good, your mainboard is cooked.
Thanks,
Adam.
Feb 19, 2011 | HP Pavilion DV9429US Notebook
Just bought a x reg ford puma but the key fob does not work, bought a new battery and fitted it, needs re-programming but don't know how to do it.
Telephone: Fax: VAT Registration No.:
Infrared remote control
NOTE: Infrared emitter can be seen at front edge of key.
System operation
Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system.
Programming
When
Key batteries completely discharged. Key batteries not replaced within 15 seconds. Key added or replaced. System malfunction.
How
Obtain all keys fitted with remote control. Turn ignition switch to position I. Wait approximately 10 seconds. Ensure clock LED illuminates.
NOTE: LED illuminates for approximately 5 seconds.
Switch ignition OFF and remove key, while LED illuminated. Programming mode activated for approximately 20 seconds (LED illuminated). Proceed as follows: Point key at receiver (located near interior lamp). Press and hold unlock button Fig. 1 [1]. After approximately 1 second key LED will flash once [3]. Press lock button 3 times Fig. 1 [2]. Release unlock button Fig. 1 [1]. Continue to point key at receiver until LEDs in clock and key have flashed 5 times. Ensure LED remains illuminated. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode and extinguish clock LED: Switch ignition ON and OFF. Wait approximately 20 seconds.
NOTE: A maximum of 4 keys can be programmed. Fig. 1
Radio frequency remote control
System operation
Pressing tailgate release button twice within 3 seconds unlocks the tailgate - if fitted. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system. Interior lamp illuminates when disarming system.
Programming
When
How
Obtain all keys fitted with remote control. Fasten seat belts and close all doors. From position I, turn ignition switch as follows: To position II. To position I. To position II. To position I. To position II. To position I. Programming mode activated for approximately 20 seconds. LED or fog lamps ON warning lamp illuminates (some models) or the system will emit an acoustic signal to indicate start of programming mode. Proceed as follows: Type 1: Press and hold unlock button Fig. 1 [1]. Type 2: Press unlock button Fig. 2 [2]. Ensure clock LED or fog lamps ON warning lamp flashes (some models) or wait for acoustic signal (indicates correct programming). Wait 2 seconds. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode: Switch ignition ON. Wait 20 seconds.
Aug 25, 2010 | Ford Focus Cars & Trucks
Dell 9300 power up issues
The issue seems with with the mainboard please get it checked.
Thanks
Feb 24, 2010 | Dell Computers & Internet
HP Pavilion zd8000 don't startup
have you even try to remove the battery in your laptop?
if not try to remove it in a miniute then put it back again.
maybe it is in standby mode.
Jan 23, 2009 | HP Pavilion zd8000 Notebook
Power LED on but no boot up
it could be your power switch, veriy that it isnt the power supply by
1.) un-plug it from the main board
2.) look at the main board connector(one coming of the power supply)
3.) you should see green wire and next to it a black one
4.) using a paper clip bridge the too wires
5.) if it works proceed to net step if not get a new power supply
to check case switch and board switch
1.) plug in power supply to main board
2.) look at the pins where the power button connects to
3.) using a metal object (blade screw driver) bridge the pins
if the board should start up>
then its your power button on the case that is bad, you can try to repair it, chage it or buy a new case,
if it doesnt work.
1.) ensure that jcms(jumper to flash the bios) is set correctly
2.) unjack each drive one at a time to see if any is causing stalling
3.) get a new main board
Jan 02, 2008 | EliteGroup L7VMM2 Motherboard
Its the Mother Board..I had the same problem and had to have a new MB put in
Feb 17, 2007 | Gateway (4000811) Motherboard
Compaq Evo N410C Notebook Logo
549 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
