Question about Maytag MGR6772BDS Gemini Gas Kitchen Range
Bottom Oven Will Not Heat Up
Of course this happened on Christmas Day! Our bottom oven stopped working. I enter the temperature I want it to preheat to, but it never heats up, the display just stays at 100 degress but it never even gets warm. The top oven is working fine. There is no error code. We've never had any other trouble with the oven. I am trying to fix it myself.
Thanks,
Tammy
  • 3 more comments
  • Anonymous Feb 22, 2008
    I have encountered the same problem and I am now just trying to research the issue.
  • Anonymous May 20, 2008
    We tried to preheat our bottom oven for dinner tonight and it will not heat up. The top oven is working fine but the bottom oven will not heat and the display stays at 100.
  • thepilot Nov 05, 2008
    Mine, a MGR6775BDS, started to do the same thing yesterday evening. Did you ever discover a solution?
  • ihateapplain Nov 22, 2008
    I have the same issue with my lower oven. I see the glow stick is heating up but the oven never starts
  • 4meyers Dec 07, 2008
    Same here. So what did you all do?
  • 60 Answers
SOURCE: bottom oven does not heat up, top oven works
the most common problem for your description is that your bottom ignitor is not working properly just because the ignitor glows doesnt mean your ignitor is working it has to draw 3 amps or more to ignite the bottom burner part number for the ignitor is 12400035 let me know how you make out
Posted on Sep 12, 2007
SOURCE: Maytag MER6772 - Oven bake element not working even after replacing it.
To find service information for your Maytag Model go tothis link
http://www.servicematters.com/
When on this site, click on Maytag Historical Service Library.
Then click on Maytag Service Library.
Click on term and conditions
Click on Literatur by Model
Enter Modle number MER 6772
Clck go
You will be able to print or download the service manual for your model
Your problem may be the bake relay on the clock or wiring.
Posted on Feb 09, 2008
catriver
  • 878 Answers
SOURCE: bottom oven element on Model MER5552BAW
magic, start with the basics first. See if you have the right power going to the oven. At the terminal block on the oven, where the cord attaches, you should have 120V from the center terminal to each end terminal. You should have 240V across the 2 end terminals. If you don't have this, there is your problem. If that's ok, check the voltage at the bake element terminals in back. Should be 240V when in bake. If that checks ok, then it would be the element itself. Check it, with power off and wires disconnected from the element it will ohm at approx. 20 to 22.6 ohms. If you don't have the power at the element then I would suspect the oven controller. The fact that it's heating to 170 degrees leads me to believe that you are missing a leg of power. Catriver.
Posted on Jun 13, 2008
heatman101
  • 43501 Answers
SOURCE: The oven shuts itself off after preheating.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Jun 07, 2010
SOURCE: Maytag Gemini bottom oven not working
both ovens on my new stainless steel maytagmgr6775 not heating up.............
Posted on Dec 11, 2010
Oven preheat countdown won't start
check your power supply ,,, oven don't run in low voltage ,,give a good earthing ,,call in a service man
Mar 31, 2014 | Whirlpool Ovens
The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool accubake doesn't preheat properly
Are both of your heating elements lighting up when you are preheating? It sounds like the oven thinks it is pumping power into both elements and one isn't working. Oven elements are generally easy to remove and replace!
Jan 08, 2018 | Whirlpool Kitchen Ranges
Bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Dec 25, 2007 | Dacor ECS230 Epicure Electric Double Oven
Kenmore range stopped working after self clean cycle
It will help to know the model number from the oven, but F2 usually indicates a failed temperature sensor on most ovens. If this is the case on yours, it will have to be replaced for the oven to operate again.
Post back with the number and I will see if I can help.Thanks/Mike
Dec 24, 2007 | Kitchen Ranges
PROBLEMS WITH FR ERROR MESSAGE APPEARING
Mewood What part did you call "thermostat"? If you?re talking about the device which operates the oven temperature, your oven does not have such thermostats. It has two oven temperature sensors (one in each oven) and a control board (ERC). An error code "F4" will be displayed along with a beeping sound if the ERC determines an open oven temperature sensor circuit. It can be the sensor itself or the wires that connect the sensor to the ERC. The F4 message will not be displayed in the time of day mode. To get access to an oven sensor and wires, the oven has to be removed from the cabinet. Then you have to remove the rear cover. Then unplug the oven sensor and check the resistance across the oven sensor. It?s supposed to be about 1100 ohms at room temperature. If the resistance is incorrect, the sensor is bad and needs to be replaced. If not, check all the wires from the oven sensor to the ERC. If it is not the sensor and wires, you have to replace the ERC, but most likely the problem is with the wires and/or connections. Part number for ERC is 62965, part number for oven sensor is 62593. Gendos....post back.
Dec 14, 2006 | Dacor ECS230 Epicure Stainless Steel...
Oven will not heat to requested temperature
Shaffy, When baking only the bake element should heat. When broiling only the broil element (upper) should heat. Your oven is a Kitchenaid, you have a 5 year warranty on any electronic element or control board. You may have a temperature sensor that is not working right. The oven just might need to be calibrated, the instructions would be in your owners manual. Your bake element might be failing, it would have to be ohmed out. You also need to verify that the bake element is getting 240V. when turned on. Catriver...post back
Sep 07, 2006 | KitchenAid KERC507 Electric Kitchen Range
Maytag MGR6772BDS Gemini Gas Kitchen Range Logo
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
