Question about Whirlpool GST9679P Top Load Washer
GST9679PBO Whirlpool Gold washer
As soon as you start the washer filling, it leaks. I can not find where it is leaking from. How do I pop open the top?
vest6
  • 196 Answers
SOURCE: Kenmore Clothes Washer leakes when filling,it's a top loader.
When you say it is leaking when it is filling, where is it leaking ? Inside or outside the machine ?
I'lll try to help once I know the answer to the above
Posted on Jan 02, 2008
SOURCE: water leaking from underneath after washer drains
I have the same washer and there is a white plastic piece underneath the washer where two hoses go into. It contains the impeller that pumps the water out. Anyway, on my machine this piece was incorrectly injection molded at the factory. The glue bubbled out causing an air bubble -- once the air bubble in the glue can stand the pressure and pops, the leak occurs!!!!! If you are a handyperson, take this piece out and use exopy to fix.
Posted on Mar 30, 2008
  • 1073 Answers
SOURCE: whirlpool washer motor hum
you may have a bad pump stuck take the pump back off you should be able to turn the pump by sticking your finger in the slot that it slides up on the motor shaft if it turns with a little resistance the pump is ok if it will not turn then it needs to be replaced
also check to make sure that the motor connector wiring is tight and the lid switch connector is tight also
Posted on Apr 16, 2008
Lumpy816
  • 246 Answers
SOURCE: Washer leaks from bottom as soon as it starts filling with water
There are 2 green clips between the top of the unit and the front panel. (you can use a flash light to find them easier). Push on the with a putty knife or small flat head screw driver while lifting on the top. Once the top is open, you will find 2 5/16 screws that hold the front panel on at the top on the right and left hand sides. Once these are removed, you can tilt the front panel forward and see where the water is leaking from.
Posted on Jun 16, 2008
SOURCE: leaking whirlpool washing machine
The exact same thing happened to me several months ago, had to replace the pump motor, works fine now. Hope this helps!
Posted on Mar 03, 2009
Water leaking from bottom of machine when water is going into the load
I suspect that the hose reaching from the water control solenoids to the fill spout is loose or damaged.
Aug 04, 2014 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
I have a Whirlpool washer that's leaking water onto the floor. Jason Harris told me to look under the heater i don't know where the heater is.
There is no heater on that machine.
Does the water leak as soon as you start the fill cycle or does it start to leak when the water level gets up to the agitator?
Oct 20, 2012 | Washing Machines
Rinsing agent dispenser empties too quickly
has the seal ring fallen away? is the flap shutting properly/ try setting it to a lower numbered setting.
Mar 14, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Water leaking on the floor while filling
Open the back of the washer. Start the fill cycle and observe where the water is leaking from. You are not going to get a full view of the entire tub by only opening the lower front access.
Feb 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cannot get the back off on my whirlpool LSL9244EQO washer to see where the leake is
The back panel does not come off, the cabinet comes off the base. Open and flip the control panel up, pop out the two gold clips, unhook the lid switch harness, and tip the cabinet toward yourself and pull off the base. Boo ya. The leak is goin' down.
Sep 17, 2008 | Whirlpool Washing Machines
I need help in opening my Ultimate Care II washer's housing
two screws on top usually on front take out flip up top you will see two gold clips on each side.take a flat tip screw driver put them in slots and pop loose remove unplug spin switch and lean cabinet forward and slide off .leak could be coming from pump tilt back first look inder it have a paint can or coffe can or tilt it way back and look under it pump on motor is probably leaking then take off case
Sep 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
May 31, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer issues
that doesnt sound right at all, no questioning you, your seeing it happen but as a whirlpool tech for MANY years thats not a normal complaint.
i assume its a top loading washer.
besides this issue have you had other problems????
did you replace pump??? reason i ask is perhaps you switched the pump outlet and inlet hoses( some models they are actually same size)
assuming they are in the respective openings, cant really see a reason as to why it would POP off unless theres a magor back pressure issue, have you checked the drainhose itself and looked for a possible blockage??
thats a pretty hardcore spring style cl;amp holding that on. make sure it pushed allthe way to the throat of pump assy
Apr 02, 2008 | Washing Machines
Whirlpool GST9679P Top Load Washer Logo
103 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
