I have a Craftsman 139.53982SRT door opener and it stopped working all together. The light on the control console on the wall is not lit. Once in a while it will light up and it works, but mostly the light is out and doesn't work. If I go up to the motor unit and tap on it the light comes on and it works. It only works for a few minutes. What could this be? All power is running in garage, and no circuits have been tripped.
You have a loose connection in the power supply or power supply board. Because line voltages are present, I would recommend you find a pro to repair this.
You can unplug the unit and pull the logic board. Check for loose connections on the printed circuit board especially around the small transformer. You will need to solder if you find these.
I replaced main sprocket & shaft today...now my opener will NOT travel down more than a few...
(More)
I replaced main sprocket & shaft today...now my opener will NOT travel down more than a few inches. I have the unit open and can see that it is not traveling the distance down..up is okay...is there a fix other than using the adjustment screws??? They do not help..the unit starts down and then reverses after a couple of seconds..HELP Please
Sears Craftsman Garage Door Opener: doesn't move the chain; the motor makes a rotating noise for a...
(More)
Sears Craftsman Garage Door Opener: doesn't move the chain; the motor makes a rotating noise for a while and stops, but no movement visible at the chain
I need to reprogram my opener. When I enter the code the lighted pad keeps flashing. I am looking...
(More)
I need to reprogram my opener. When I enter the code the lighted pad keeps flashing. I am looking for a manual or some guidance.
