Question about Phase Linear UDV9010 Car DVD Player
Distortion how do you filter out the noise?
Connecting the black cable in a good screw, sanding if possible to remove paint or dirt, and ready your noise Disappears
Posted on Apr 19, 2008
Intex Model ECO 20110 Leak at Pump Housing and Pre-Filter, today, louder Noise when operating, but still pumping. Can it be repaired or replaced without buying entire unit. Sand Filter/Salt Water
you can replace motor only but if loud bad bearings and getting hot and ruining seals and distorting housing replace whole pump less hassle
Jul 16, 2018 | Intex Pool & Spa
Front end thumping noise when brakes applied
Could be a distorted rotor, loose wheel nuts, loose wheel bearing nut, break pads that are u7nevenly worn.
Jul 18, 2013 | WWFG 1994-2002 Chevrolet Astro Van Custom...
Distorted sound from new Dell desktop
1. In most cases the problem maybe due to the powersupply. If the filter capacitor or the diodes are not working properly in the power supply, it could give the distortion sound. Use a different powersupply to see if it solves the problem.
2. The mic wire can also catch some hissing noise sometimes. Disconnect the mic wire from the motherboard and see if it solves the problem.
Thanks
Jul 02, 2009 | Dell Inspiron 530 Desktop Computer
GE D52GW12, picture is distorted and snaps
its either the HV splitter or the flyback which needs replacement. You can get both items at the following link with free instructions.
http://servicemanuals.vstore.ca/
Mar 26, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Distortion lines on pictures taken with a wide angle lens
The ISO is set too high, lower the ISO to 200 or set it to auto, try it you will find that the noise from photos will dissapera
Jan 05, 2009 | Fuji Fine pix S3 pro Digital Camera with...
Directed 10.2 dvd
add a noise filter in the input voltage good luck sorry my write i'm mexican technichian from tijuana
May 03, 2008 | Directed OHD1021 Car Video Player
Distortion
maybe you have a wrong conecction of your component, many times, distortion is caused by noise from enginee
Dec 28, 2007 | Jensen VM9510 Car DVD Player
M-Audio FireWire 410 External Distorted Playback...
Hello have you disabled all the built on sound cards on your computers? This is a known problem. If you are going to use a great product like M-audio disable any onboard audio card. Then try to use the 410 system. If you still have the problem try changing the latency to 4-5
Dec 27, 2007 | M-Audio FireWire 410 External Sound System
Distorted color on image
You might have "color filter" settings. Turn the digital filters off. Here is what manual at p72 says. "You can take pictures using digital filters. The filters consist of color filters such as red, blue and green, a soft filter that produces a fuzzy effect. Color filters Eight colors, black-and-white, sepia, red, pink, violet, blue, green and yellow, are provided for the color filters. When you select a color filter in the Digital Filter mode, the display on the LCD monitor is filtered with the selected color, and the pictures are taken in that color."
Mar 20, 2007 | Pentax Optio 555 Digital Camera
Phase Linear UDV9010 Car DVD Player Logo
23 people viewed this question
Top Phase Linear Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
