My GE top-load washing machine skips directly to "final spin" when I try to wash clothes (no water comes out, the cycle just goes directly to "final spin" every time).
If your GE GFW650 front-load washer is skipping directly to the end of the cycle without spinning the clothes dry, there are a few possible causes that you can investigate: 1. Unbalanced Load: If the load of laundry is not evenly distributed in the drum, the washer may not be able to balance it properly during the spin cycle. This can cause the washer to skip the spin cycle and go directly to the end. Try rearranging the clothes in the washer and restarting the cycle. 2. Blocked Drainage: If the washer is unable to drain water from the drum, it may skip the spin cycle and go directly to the end. Check for any blockages in the drainage system, such as a clogged drain hose or filter. Clean or replace any blocked components. 3. Faulty Motor: If the motor that drives the spin cycle is malfunctioning, it may cause the washer to skip the spin cycle and go directly to the end. This is a more serious issue that may require a professional repair. 4. Malfunctioning Control Board: If the washer's control board is malfunctioning, it may not be able to properly control the spin cycle. This can cause the washer to skip the spin cycle and go directly to the end. Again, this is a more serious issue that may require a professional repair.
If none of these solutions work, or if you are uncomfortable performing any of the troubleshooting steps, it may be best to contact a professional technician to diagnose and repair the issue.
The amount of creasing you will get is directly related to the speed you select for the final spin dry cycle and the spin after the first wash cycle which occurs prior to the rinse cycle. The higher the speed and the longer it goes for the more the clothes will crease.
Experiment with different spin speeds on your machine for clothing that is subject to the creasing problem. Also do not put too many items in the machine for a wash as many people do as this will contribute to creasing. Always under load your machine for every wash cycle.
Spin drying is a compromise between creasing and maximum water removal. If you want less creasing you will need to select a more gentle spin dry speed but you will also have the clothes coming out of the machine with a higher water content and they will take a bit longer to dry. The spin time on the program may also be shorter.
In my own machines I use a gentle wash and spin cycle for all clothing that I don't want heavily creased. Running it on a wash cycle with a high and longer spin speed when the machine is spinning the clothes after the initial wash, and then again after the final rinse, will thoroughly crease the clothes every time.
Also bear in mind that different fabrics that are suitable for machine washing will perform differently and some are just too subject to creasing even if you use the most gentle wash, rinse and spin cycle. Hence you can take 2 different 100% cotton fabrics out of a machine and hang them to dry and one will be almost crease free and the other will be thoroughly creased. With these fabrics that are just very subject to wash creasing, it is better to hand wash and rinse them. Then after rinsing drip dry them or put them in the machine and spin them for 1 -2 minutes maximum just to get some of the water out and hang dry them.
Could be that the spin cycle is not rotating at the required speed to wring out your clothes. Check that the cycle completes at a significant speed to generate centripetal acceleration forcing out the water. Perhaps the load is unbalanced which can trigger the spinning cycle to repeatedly stop during the spin cycle.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
the agitator shaft could be stripped out. does it sound like the motor is working during the wash cycle or is it just idle? This is a common problem with ge washers the agitator strips out on the transmision and needs to be replaced.
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
