The first thing I would check for is bad convergence chips-in PARTICULAR if the 'colors looked weird' just before it died. bad convergence chips--probably STK 392-110's (which should be UPGRADED to 392-150's) are very common in these sets.
Don't open up the TV. You may regret it. Unplug the set for 5 minutes....not just shut off....uplug the power plug from power source and replug after 5 minutes. It may need resetting.
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Try pushing the "source" button on remote or on the TV. Wait about 5 seconds, if no picture, push again. Do this at least 6 times or until you get a picture. With each push, the TV will look for cable input, dvd input, etc. until it finds your cable signal.
Also make sure your cable/antenna is hooked up and working.
If that doesn't work, hold down the "enter" button for 10 seconds to reset the tv to original factory settings. Then follow the on-screen menu setup instructions.
Hi, Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number... A1085447A* LAMP BLOCK ASSY XL-2200U It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
It sounds like you need to re-register the earpiece to the base. To do this, use the following steps:
1. Return the headset to the Headset Docking Cradle 2. Press and hold both the Speak Volume Adjust Buttons (+/-) on the back of base unit for a minimum of 5 seconds. The Red Power Indicator will then flash 3. Press and hold the Headset Mute Switch (black button on top of earpiece) for a minimum of 5 seconds. The On-line indicator (green light on boom) will then illuminate. 4. Subscription completion is indicated when the Power Indicator is fully illuminated and the On-line Indicator is extinguished. 5. If subscription fails within 2 minutes the headset will return to the un-subscribed state.
to set remote to tv
1)hold down tv button next to sat button in top left corner 2) when all buttons illuminate press 500 into remote 3)press pound sign 4)Hello, please help.. 5)hold town tv button again. 6)when all buttons illuminate press big red power button 7)press up arrow once a second until tv shuts off 8)press # pound sign 9)try to turn tv back on w/ big red power button 10)if tv doesnt turn back on try again from step 2 but use down arrow instead
to set remote to receiver you need to access system info, if there is no sys info button on your receiver turn power off and press the up arrow, then press record 2 times on the remote,
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
