Question about Nikon MC-EU1 LCD Remote Control
Sharper image universal remote control
Can't figure out the code for General Instruments cable box. Tried the Jerrold codes, used code search. Nothing. I seem to remember years ago that my dad could program a universal remote by pointing the two remotes at each other and code searching. Can this be done? I gave it to him for Christmas and really want it to work.
3 Suggested Answers
SOURCE: Remote control codes for general instruments cable box
i have a curtis mathes tv called an itronics and i need a remote controll code for it
Posted on Aug 14, 2008
  • 4 Answers
SOURCE: Need remote code for cable box
hold setup button down push ch up untill tv turns channel hit enter
Posted on Jan 10, 2009
I have a Sharper image universal remote control and a LG TV I need to know how to program the remote to TV..don't have book on either one..?.please help me
Use code search on the remote control to find something that works. If a search through all codes stored in the remote control fails, you may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Jul 11, 2017 | LG Televison & Video
I have a HiSense tv and the original remote broke and it's stuck on a certain input....I have the sharper image jumbo universal remote and can't figure out how to program it to my TV, so I can switch the...
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Nov 23, 2014 | Televison & Video
Code for sharper image jumbo tv remote to operate a motorola brand cable box. remote instructions dosn't list it and code search is not successful.
If you go to a website called Scroll down to the bottom of the page click on The Sharper Image Universal Jumbo Remote then click download. The manual has the instructions and codes. Good Luck. Source(s):
Jan 30, 2010 | Televison & Video
Through Amazon a Brookstone's "Jumbo Universal Remote" was delivered - there is no identification of who manufactures this remote. We need to have it control an AT&T-California cable box which was...
I happen to be a Jumbo Universal remote Expert here at Fixya, so I hope I can help. It is possible that this remote just won't run your Motorola cable box, but I wouldn't give up until I had tried the codes from the list in the manual, as well as run through the auto-setup feature of the remote for CBL and for SAT, where it just tries all the cable box codes one at a time.
I was able to find a working motorola codes for an Innovage Jumbo Remote, a three digit code remote you might as well try: 051.
You have probably tried the codes for Motorola (031) and GI (000, 032) from the manual using these steps:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device. (000, 031 & 032 for example)
3. Press and hold the corresponding button on the remote control
(CBL) for approximately three seconds. The POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press the ON /OFF button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code located on the Code List.
If those are still a bust, try the GI SAT codes 018 & 019.
Have you tried the following steps with both CBL and then SAT to search it's database?
2. Press and hold the corresponding button on the remote control
(SAT or CBL) until the POWER INDICATOR on the remote control illuminates. The remote control is in programming mode.
3. Press and release ON /OFF. The POWER INDICATOR on the remote control flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns off.
5. When the device turns off, press any key to store the code.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
I hope that helps.
Oct 26, 2009 | Televison & Video
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Dec 27, 2008 | Televison & Video
Gain control of my Motorola cable box with a Sony RM-Y167 remote
Cable Converters (Set Top Boxes)
Director 0476
General Instrument 0476
Jerrold 0476
Motorola 0476, 1376
Pioneer 1877
Scientific Atlanta 1877
Feb 12, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Need remote code for rca dvd/vcr combo using a sharper image univeral remote
Use code search on your Sharper Image remote control to find something that works. If a search through all codes stored in the remote control fails, you may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Jul 24, 2017 | Televison & Video
Sharper Image Jumbo Universal Remote
i just pirchased a Sharper Image Jumbo universal Remote but i can't find a code for the Pioneer DVR 541H is DVD recorder. Does anyone have this code or  a suggestion?
Jan 10, 2008 | Televison & Video
Find Code for Motorola Cable Box which Works for the Innovage Jumbo Remote Control
Had the same problem with my Jumbo Remote - found the code under the "General Instruments" list (051 for me). Also noticed that my cable box has a sticker on the front with a serial number starting with "GI," most likely more evidence of the General Instruments conection. Able to get all the functions to work: guide, menu, etc. Good luck!! - JQ
Dec 21, 2007 | Televison & Video
Nikon MC-EU1 LCD Remote Control Logo
126 people viewed this question
Top Nikon Televison & Video Experts
Are you a Nikon Televison and Video Expert? Answer questions, earn points and help others
