Question about Comfort-Aire EKTC12-150J Air Conditioner
No Heat I have Comfort-Aire EKTC15-150B and the heating element is not coming on. The Fan will run but we do not get heat. We had a power outage and it was about the same time the heat stopped working. Is there a manual reset or fuse that needs to be change? Any help would be greatly appreciated it's cold today. Thanks
  • Anonymous Mar 24, 2014
    this is a window AC/Heat unit, heat unit wont kick off at desired temp setting.
  • 80 Answers
I NEED TO KNOW IF THIS IS A SPLIT SYSTEM ONE INSIDE ONE OUTSIDE OR IF IT IS A PACKAGE UNIT ONLY ONE OUTSIDE OR IF IT IS A WINDOW UNIT SELF EXPLANITORY?
IF YOU GIVE ME THIS INFO I CAN HELP YOU
Posted on Dec 27, 2007
Hf3163tn fan and heating element not working. has power to elements and to switches
I'm not familiar with model number;but with fan ovens ,if the fan fails the element it blows onto will over heat and burn out .Its a common fault .
Check for power on fan and element .
If fan doesn't run with power on, or runs slowly or stops occasionally and element with power on does not heat,both will need replacing.
Good luck.
Feb 21, 2018 | Ovens
Comfort-Aire REG-183 18,500 BTU Window Air Conditioner & Heater cuts on and off when not set to auto on heat only
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
Air Bulance AC Cleaning Repair Services
Apr 04, 2015 | Comfort-Aire Heating & Cooling
My remote will not change the fan speed on my mini split heat pump in the heat mode but will change speed in cooling mode. checked batteries and pressed restart button no changes
in the heat mode the fan mode run automatically first in low mode and after a while it run normally ,how you set on the remote.if you can-t set on the remote is possible to have problem to the remote.
Dec 12, 2013 | Comfort-Aire EHW 12 Air Conditioner
Heat elements won't come on
Check your breakers if they off flip them on if it does it again call us no amount of help on here can guide a DIY homeowner in proper diagnostics on this issue your playing with high voltage and your life.
Nov 26, 2013 | Comfort-Aire Heating & Cooling
Zone aire ptac
sounds more like a relay
Nov 15, 2013 | Heating & Cooling
Comfort aire overtemperature switch part no. 47-21900-01 I am looking for this part. thanks stew
Call Heat Controller in Tennesse they distribute this although it is made by LG
Jan 22, 2010 | Comfort-Aire BHD-501 Dehumidifier
Air conditioner not working.
Assuming this is a dual unit heats and cools. You may have a sticking transfer valve or a defective compressor. The trf valve simply switches the cool to the heat. Suggest you contact a qualified ac technican.
Sep 08, 2009 | Heat Controller PE121A Air Conditioner
Quit working
Based on the limited info.I have, it sounds like the heating element is not getting power. suggest visually inspecting the switch and thermostat for burnt wires. Also check the heating element for broken electrode.
Nov 08, 2007 | Comfort Zone CZ-530 Compact Heater
Heating & Cooling Logo
302 people viewed this question
Top Comfort-Aire Heating & Cooling Experts
Cesar Quant
Cesar Quant
Tim Whalen
Are you a Comfort-Aire Heating and Cooling Expert? Answer questions, earn points and help others
