Question about Motorola Mobility E815
E815 display display is week but can be seen. got wet. I wonder if these gurus are allowing real answers to be displayed. I havent seen any real solutions on the sight but have on others?
  • picthis1 Jan 24, 2008
    E815 got wet. All functions work with the exception of the LCD. It is barely visable. I replaced with a known working LCD and it did not correct the problem. I also used a known working flex cable.
  • 38 Answers
Here is the real answer. and I'm a rookie "here".
you need to replace the LCD and flex all together.
Any help or question please ask.
Thanks
Posted on Jan 07, 2008
  • CellTech Jan 22, 2008
    Did some research and found a people on ebay selling lcd and flex cables for this phones here is the link:
    V710 E815 OEM flex cable
    Hope this helps.
Just installed furnace, turned on heat, everything running good. Water seen on floor under unit, don't know source, considerable amount of it.
thats your answer the steam from wet clothes turn to water if you havent connected the outside vent iit will be the reason there is water on floor
Oct 14, 2014 | Dryers
My Pioneer DVD player displays OC ERR 1
You need to replace the IC Amplifiers that is near the channels when you open the player (make sure it is NO LONGER under warranty or else you'll void it). The cause perhaps is that your speakers have been shorted.
Aug 20, 2012 | Pioneer HTZ-161 Theater System
My problem is my inside screen went blank white. About a week ago the inside screen started to do weird stuff like one day it had multi colored snow. The next it went blank. The next it looked like liquid...
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Oct 05, 2010 | Motorola Mobility E815
Take care.
The camera and video camera stopped funtioning. It
try to delete some pictures, recordings and videos, sometimes the reason why it has a message like that is because the memory of your cp is already full
Nov 21, 2009 | Motorola Mobility E815
Problems
For some reason my E815 has no service and it sometimes will comback for like 30 seconds and goes away again
Sep 10, 2008 | Motorola Mobility E815
Display intermittant for few weeks, now no display or oven control
real easy trouble shoot, check the wiring diagram out and find where the line voltage goes into the board. if you have voltage to the board and no display it is very likely a bad board also make sure you have ground pathway from the board. you can have voltage to the board but if no ground pathway then the board will not work. a cheapo meter from sears etc. will work
Apr 22, 2008 | Maytag MER5530 Electric Kitchen Range
Display is faint E815
New flex with LCD is needed. Check out my other comments as i have added a link of where to get this parts.
Thanks
Dec 26, 2007 | Motorola Mobility E815
Internal screen is white
NO YOUR DISPLAY IS DAMAGED YOU HAVE TO CHANGE UR PHONS DISPLAY AND IT WILL WORK EVEN CHANGING THE DISPLAY IF IT DONT WORK CHECK THE DISPLAY CONNECTOR.
Nov 23, 2007 | Motorola Mobility E815
Motorola E815 Display Screen Blank
Flex cable connected to the main board tend to get loose. You need cell technician to fix that problem.
Oct 22, 2007 | Motorola Mobility E815
Motorola Mobility E815 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
