Maytag PAV2300 Top Load Washer
Problem for Maytag PAV2300 Top Load Washer
Hello. I think this is the model..it looks
By tonyandbridi on Oct 12, 2009
Hello. I have a top loading Maytag washing machine that must be about 15 years old???? Anyhow it has recently developed a "lint" problem. Leaving lots of junk on the finished wash. Would there be a filter I haven't known about for the past 15 years? Thanks so much! Regards, Bridie
Clarification Request
Posted by Turo on Oct 12, 2009
Usually there is a longish filter that has to be cleaned time and again. If this hasn't been cleaned you will surely have this problem. the filters are usually on the surface of the drum it will bulge out, teh manual will certainly help u check it out. Also check if the drain pipe has an obstruction either due to some residue of cloth fiber
Best Solution
posted on Oct 12, 2009
Helpful)
lilhelper
Rank: Guru  Washers & Dryers  Expert
Rating: 96%, 45 votes
Well Bridie no there is no lint filter inside your washer the only possible explanation, is either old lint and particles are coming from previous washes. or you have just washed something recently that may have come apart such as a pillow, a mat with a rubber backing, or even a blanket with any sort of fiber material in it. It is more than likely that much of the lint that goes through your machine is unseen and can cause pump issues. hope this helps.
Thanks
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
" PHEW! thanks for that explanation! We have recently been away for a # of months so WHO KNOWS what the teenagers have washed in the machine! thanks! " - tonyandbridi
Popular Solutions for Maytag PAV2300 Top Load Washer
Questions and Unsolved Problems for Maytag PAV2300 Top Load Washer
Do you recommend Maytag PAV2300 Top Load Washer?
Answer
Answer
I have a Maytag Performa model# PAVT244AWW. The machine keeps spitting water over the top of the tub... (More)
Answer
Program will not edit, Says edit is not compatible. I use Windows 7. is there a dowload to correct... (More)
Answer
My Maytag is leaving stains on my clothes, not sure if it could be oil or grease, don't notice it... (More)
Answer
after spin cycle, tub tries to fill but water runs out immediately. I cannot hear the pump running... (More)
Answer
what causes a high pitched noise when it starts to drain the water before spinning
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Maytag PAV2300 Top Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14823
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
